Front indicator - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front indicator (/showthread.php?tid=77849) |
Front indicator - Adscan - 04-04-17 Had a little accident and need to replace the front right indicator. Are they side specific or can i get either left or right side to replace it with? Re: Front indicator - darrsi - 04-04-17 Can't see specifically, but on Ebay they do tend to be all named either left or right so may as well just get the appropriate one. Re: Front indicator - bandit - 04-04-17 As darrsi said get one on Ebay for the side you want,the stalks are the same but the lenses are sided as they have the word top on them why i'm not sure.
Re: Front indicator - Adscan - 04-04-17 My current lense is okay, just the stalk that is knackered. Only decent ones on eBay appear to be left side. So if my lense is okay i can get a left side and put my good right side lense on? Re: Front indicator - Frosties - 05-04-17 Is it worth moving your left indicator over to the right to see before you buy ? Re: Front indicator - midden - 06-04-17 (04-04-17, 11:22 PM)Adscan link Wrote: My current lense is okay, just the stalk that is knackered. Only decent ones on eBay appear to be left side. Are you sure the stalk is knackered and not just pushed in to the fairing. It's held by a rubber grommet Re: Front indicator - celticdog - 06-04-17 (05-04-17, 11:15 PM)Frosties link Wrote: Is it worth moving your left indicator over to the right to see before you buy ? Won't that make it wink in the wrong direction?!?
Re: Front indicator - Adscan - 06-04-17 Are you sure the stalk is knackered and not just pushed in to the fairing. It's held by a rubber grommet you are right...it has pushed through, the only problem is that the screw that secures the indicator plate is rounded off. I will end up having to grind the screw down. Re: Front indicator - Adscan - 06-04-17 All sorted now...i got the screw out in the end. Thanks for the advice! |
