Bike didn't start! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bike didn't start! (/showthread.php?tid=77810) |
Bike didn't start! - ben17484 - 30-03-17 This morning I got on my bike to come to work and it wouldn't start. I did my usual of turning the choke on (and checked that the bar moved on the carb, so the cable is definitely working), slight throttle and starter button, but it just sat and churned away but didn't start. Eventually the batter died so i had to put the bike away and get the train to work. I haven't used the bike in anger since last Friday, but did go for a quick spin around the block yesterday and everything seemed fine. Where would be a good place to start looking for the issue? Cheers, Ben Re: Bike didn't start! - Fazerider - 30-03-17 Once hooked up to a charged battery, I'd see if there's a spark available at all 4 leads. However, if it was my bike, I wouldn't expect it to start... full choke is a reliable way to flood it unless the temperature's about -5ºC. Re: Bike didn't start! - ben17484 - 30-03-17 Ok, cheers. I'll try that on the charger. I did wonder if I'd flooded it. Would you not use the choke at all in the spring/summer/autumn then? This is my first non fuel injected car/bike. Re: Bike didn't start! - bandit - 30-03-17 I use the choke all year round with no ill effect.[img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] As Fazerider said charge battery & try starting again,it maybe time for a new one do you know how old it is. Re: Bike didn't start! - Fazerider - 30-03-17 (30-03-17, 10:00 AM)ben17484 link Wrote: Ok, cheers. I'll try that on the charger.I need about one quarter choke if the temperature is around freezing, but otherwise none at all. The slow jet runs on the rich side at the usual 2-turns-out setting. In fact, I leave mine at 1.75 turns and it's still ample... but bikes vary, yours may be different. Re: Bike didn't start! - ben17484 - 30-03-17 I've only had the bike a month so most of that time it has been fairly cold. Not tried starting without the choke yet but will do now the weather is a bit better. No idea how old the battery is, but have read that even though it was turning over for quite a while (therefore I assumed the battery was fine) the batter may be at fault? If this is the case, presumably starting on a battery charger should resolve the issue and I can then replace the battery? Re: Bike didn't start! - Jules-C - 30-03-17 Often needs a bit of throttle to get started. Try about 1/4 choke and then press starter button and gently open throttle to about 1/2 way taking about 2 seconds get there. That often works on many bikes with chokes. If you're used to fuel injection you've probably been told not to touch throttle when starting the engine, that's not because the engine doesn't need it but the electronics are doing it for you without you knowing about it. Re: Bike didn't start! - bandit - 30-03-17 ben17484,charge the battery with a charger first, not with the battery charger connected.[img alt=Shocked]http://foc-u.co.uk/Smileys/efocicon/shocked.gif[/img] Re: Bike didn't start! - ben17484 - 30-03-17 Ok, will do cheers. So the chargers aren't like the battery boost ones that you can get for cars that will allow you to start the bike/car with the charger in boost mode whilst attached to the battery terminals? I've ordered the battery charger which should be through tomorrow. So even though the bike was turning over for a long time, it could still be the batter that's the issue? Re: Bike didn't start! - ben17484 - 30-03-17 Another possibly stupid question - can I try and jump start the bike from my car to see if the battery is the issue? Re: Bike didn't start! - ben17484 - 30-03-17 A quick google suggests I can jump start a motorbike from my car (without the engine running on the car) Re: Bike didn't start! - bandit - 30-03-17 Yes you can but be careful connecting the large car jump lead clips to the small terminals on your bike. It is not uncommon for the original battery to last this long if it is a black battery possibly a GS Yamaha Motor Company one this would more lightly be the original Yuasa/Lucas or branded other would be later replacement with a life of around 5-10yrs service. http://www.ebay.co.uk/itm/GENUINE-YUASA-YT12B-BS-MOTORBIKE-QUAD-JETSKI-BATTERY/130494954517?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40802%26meid%3D3334ef489381491cb5049e9490a8a59d%26pid%3D100005%26rk%3D2%26rkt%3D6%26mehot%3Dpp%26sd%3D300683821985 Re: Bike didn't start! - darrsi - 30-03-17 I've still got issues with starting my bike as well after it's been sitting still overnight, or all day at work. Tried everything so far, and i can't even blame the weather now either, but narrowed it down to be fuel related. I syphoned out the fuel in the tank the other day, and drained the carbs, and there was no hint whatsoever of water in it. But still, embarrassing as it is, i have to slosh the fuel about by rocking the bike side to side, then it will start and run perfectly. If i try just starting it without moving it from the sidestand it simply will not have it? Totally baffles me, but at least i know how to work around it now. :\ Re: Bike didn't start! - BBROWN1664 - 30-03-17 1/4-1/2 choke is all I ever needed on my FZS600 to start it and then maybe a tad more to keep it running on the coldest of mornings. It sounds like you may have flooded it and then drained the battery. Charge the battery or jump start the bike with a small amount of choke (or none to start with) Re: Bike didn't start! - ben17484 - 30-03-17 (30-03-17, 01:28 PM)darrsi link Wrote: I've still got issues with starting my bike as well after it's been sitting still overnight, or all day at work. Funny you should say that - the only time i've had any issue before was when starting up to come home from work one day on the side stand and it wouldn't start. I then sat on the bike and rocked it and it started ok. I would have had at least over a half a tank of petrol, so it shouldn't have needed the rocking. That's the only time I've had it happen though. I wonder why that is. Re: Bike didn't start! - darrsi - 30-03-17 (30-03-17, 02:39 PM)ben17484 link Wrote: [quote author=darrsi link=topic=22260.msg257055#msg257055 date=1490876921] Funny you should say that - the only time i've had any issue before was when starting up to come home from work one day on the side stand and it wouldn't start. I then sat on the bike and rocked it and it started ok. I would have had at least over a half a tank of petrol, so it shouldn't have needed the rocking. That's the only time I've had it happen though. I wonder why that is. [/quote] I really don't know but if you find out please don't hesitate to let me know. :lol Re: Bike didn't start! - Grayo - 30-03-17 If the bike needs to be upright then this sounds like a problem with the tilt switch to me. Re: Bike didn't start! - ben17484 - 30-03-17 (30-03-17, 04:04 PM)darrsi link Wrote: [quote author=ben17484 link=topic=22260.msg257061#msg257061 date=1490881187] Funny you should say that - the only time i've had any issue before was when starting up to come home from work one day on the side stand and it wouldn't start. I then sat on the bike and rocked it and it started ok. I would have had at least over a half a tank of petrol, so it shouldn't have needed the rocking. That's the only time I've had it happen though. I wonder why that is. [/quote] I really don't know but if you find out please don't hesitate to let me know. :lol [/quote] will do - but I'll more than likely just keep rocking it like you do
Re: Bike didn't start! - ben17484 - 30-03-17 (30-03-17, 04:20 PM)Grayo link Wrote: If the bike needs to be upright then this sounds like a problem with the tilt switch to me. I've only had it happen once (well, twice including today). I did try putting it on the center stand this morning just in case it was something to do with the side stand switch, but to no avail. Could have been flooded by that point though. Do you know where the tilt switch is and how to test it? Re: Bike didn't start! - darrsi - 30-03-17 (30-03-17, 04:20 PM)Grayo link Wrote: If the bike needs to be upright then this sounds like a problem with the tilt switch to me. Just had a look around the site and apparently the FZS600 doesn't have a tilt sensor. |
