Paint code ?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Paint code ?? (/showthread.php?tid=77806) |
Paint code ?? - Dinger1962 - 29-03-17 Hi chaps sticker under my red/black/silver x reg FZS600 seat reads 5DMA-O70 ----then below that is the letter A --which bit is the paint code please as my mudguard and tailpiece are fading cheers Stu-- Re: Paint code ?? - bandit - 29-03-17 Can't help you with the paint code thing but have you tried T-CUT or AG to try & bring the colour back I take it's red which is the culprit,as it's the top clear coat that has faded it maybe worth a try,better with a machine buffer but can be done by hand then a good resin polish. [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] Re: Paint code ?? - Dinger1962 - 30-03-17 thanks will give it a go cheaper than paint can always paint if it does not work out-- Re: Paint code ?? - Dinger1962 - 02-04-17 Ok now well had no luck polishing still need paint code see above thanks stu-- |
