EXUP error issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: EXUP error issue (/showthread.php?tid=77802) |
EXUP error issue - JD-LincsUK - 29-03-17 Hullo chaps and chapesses, Having locked my baby away for the winter - too much salt around these parts - on my second ride after the thaw, the rev counter started doing the EXUP dance. I didn't notice any issues, so I took it to my very experienced mechanic friend, who gave it a good once over and lubed it up. The fault indication disappeared. Even though nothing was visibly wrong in the first place. Yesterday I took it for its MOT (just 2-3 miles away) and on the way home, the rev counter started doing the 7,000 thing again. Bike still feels just fine, though. Any ideas? TiA Re: EXUP error issue - PieEater - 29-03-17 It's possible that the cables need adjustment rather than the valve needing lubrication check out the link to Pat's guide in the FAQ at the top of this section. Re: EXUP error issue - JD-LincsUK - 30-03-17 Thanks - I'd actually saved all that info when I first signed up here, but I had forgotten about it. Reckon I'll do a complete overhaul of the EXUP. It could probably do with it. Re: EXUP error issue - Nellog - 11-05-17 Hi JD. I had similar EXUP fault indicator problems. I cleaned and lubed the damned thing til I was blue in the face and still it reared it's ugly head. I threw caution to the wind and tightened the cables to what I thought was too tight (no measuring, just went by feel on the spanner!). The cables were tight, with no discernible movement. I then loosened off 1/4 turn and hey presto! No 7000 dance As you noted, I, too, noticed no change when it started but just wanted to stop it happening! Either way, I keeping up a regular service on it.
Re: EXUP error issue - Dustydes - 12-05-17 The cable can go tight inside the inner, drip some 3in1 onto top of cable and let it run through. Just rebuilt mine. One tight cable, needed oil. Could hardly move, now moves perfectly. One frayed cable rusted onto cam.Replaced inner cable Cam wheel rotted/replaced All new stainless bolts valve cleaned and greased Re: EXUP error issue - ogri48 - 12-05-17 i had the same problem and it turned out to be the exup motor. unusual, but it happens. If you whip the motor out you should be able to turn it by hand, though its pretty firm. my old one needed grips to turn it |
