Judder/hesitation help! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Judder/hesitation help! (/showthread.php?tid=77797) |
Judder/hesitation help! - drew70311 - 28-03-17 Hi you lovely people! Can anyone help me diagnose a problem. I have a judder / hesitation when pulling away in first. It shows up now and again through other gears and rev ranges. I've checked all fuel pipes they are in good order not kinked etc... The exup is working as it should. Any other ideas??? Thanks! Re: Judder/hesitation help! - PieEater - 28-03-17 You could check your chain slack, should be 45-55mm, I had similar judders when my chain was too slack. Re: Judder/hesitation help! - drew70311 - 28-03-17 Cheers, I'll have a look
Re: Judder/hesitation help! - ste131 - 28-03-17 Check for loose connections on the ignition system too. Coils in particular. Had similar problems on other bikes and can be hard to find cause. |
