Gear Indicator plug and play. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gear Indicator plug and play. (/showthread.php?tid=77786) |
Gear Indicator plug and play. - ste131 - 27-03-17 Hi All, Has anybody fitted one of these? I had a Datatool one on my 600 and was a pain to set up and quite slow to register and got confused quite a bit! Found this on Fleebay and would like thoughts please! http://www.ebay.co.uk/itm/YAMAHA-FZS-1000-FAZER-2001-2010-GPT-GI1PNPY-DIGITAL-GEAR-INDICATOR-PLUG-PLAY-/361654385780?hash=item543447fc74:g:NxQAAOSwIgNXkO~W Re: Gear Indicator plug and play. - robbo - 27-03-17 Not familiar with the one in your link. I fitted the Healtech GiPro, which is definitely plug'n'play, but a fair bit more expensive. Re: Gear Indicator plug and play. - ste131 - 27-03-17 Cheers Robbo. I don't mind investing for the right bit of kit. Don't want one with the sensors that you have to attached like a door sensor on a house alarm! Re: Gear Indicator plug and play. - Rob R - 27-03-17 Looks a lot like the PZracing gear indicator which is also made in Italy. Don't know what a DLC port is but if its the same as the wiring for the PZR it is true plug & play only £30 cheaper! Rob Re: Gear Indicator plug and play. - Grayo - 27-03-17 I bought the PZ Racing one for my Gen2 and it was simple to set up. It was quite expensive though. Re: Gear Indicator plug and play. - ram - 27-03-17 (27-03-17, 09:14 PM)Rob R link Wrote: Looks a lot like the PZracing gear indicator which is also made in Italy. Don't know what a DLC port is but if its the same as the wiring for the PZR it is true plug & play only £30 cheaper!DLC is Diagnostic Link Connector Re: Gear Indicator plug and play. - jeffco - 28-03-17 I have an Acumen one fitted ,its been problem free Re: Gear Indicator plug and play. - ste131 - 28-03-17 Cheers for the info. I've ordered the one in the link and will let you know when it's fitted. Re: Gear Indicator plug and play. - ste131 - 04-04-17 Came today and fitted. Quite an easy job and works very well. Very happy! Re: Gear Indicator plug and play. - ProdigalSon - 07-04-17 Does it come with the mounting bracket or did you have to make that, sorry I can't access fleabay at work, I have a Datatool one that was fitted to the bike when I bought which is slow and easily confused. I do like having a gear indicator though so something a bit sharper would be nice, let us know how you get on with that one please?
Re: Gear Indicator plug and play. - ste131 - 07-04-17 Bracket was made. Easy enough though. The gear indicator works very well. Almost instant. Only time it gets confused is if you coast a little with the clutch in and blip the throttle. Understandable though. Very happy with it. Re: Gear Indicator plug and play. - nobrakes - 09-05-17 (07-04-17, 08:51 PM)ste131 link Wrote: Bracket was made. Easy enough though. The gear indicator works very well. Almost instant. Only time it gets confused is if you coast a little with the clutch in and blip the throttle. Understandable though. Very happy with it. Just plug and play in the front of the speedometer? No soldering? :eek Re: Gear Indicator plug and play. - ste131 - 11-05-17 It comes with wiring to plug into speedo sensor plug which is located behind right side cover where fuel pump is. Also need to connect to grey pickup wire also in same place and I used the rear brake switch positive for the switched live. Very easy job. |
