rear sprocket run out - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: rear sprocket run out (/showthread.php?tid=77749) |
rear sprocket run out - daviee - 23-03-17 how much run out in the rear sprocket is acceptable noticed that i have about 2-3 mm run out on mine cant see anything wrong its a new sprocket no play in the sprocket carrier bearing or wheel bearings , i have ordered another carrier to try to see if it makes difference anyone any ideas ?? Re: rear sprocket run out - Koreanbaz - 23-03-17 is the wheel definitely straight? Re: rear sprocket run out - daviee - 23-03-17 yeh the wheel is good its only the rear sprocket that looks buckled Re: rear sprocket run out - celticdog - 23-03-17 What about the cush rubbers? Re: rear sprocket run out - daviee - 24-03-17 Nothing wrong with the cush rubbers wouldn't think they would cause the sprocket to look buckled as i said no play in any of the bearings or cush drive so I'm stumped spindle looks strait aswell Re: rear sprocket run out - vinnyb - 24-03-17 Have you laid the sprocket on a flat surface like a pane of glass or a mirror? If it's brand new it may have been hardened or tempered badly. Re: rear sprocket run out - daviee - 24-03-17 going to have another look at it at the weekend cheers for the suggestions Re: rear sprocket run out - daviee - 24-03-17 can i as for some to check the run out on their own sprocket as in put the bike on the centre stand and run it in second gear and have a look at their rear sprocket to see if they have any side to side movement it would be appreciated Re: rear sprocket run out - Frosties - 24-03-17 By design, you'll always have a bit of run out due to the cush rubbers so my money is on "They all do that sir" with slight variations on degree of run out. Re: rear sprocket run out - daviee - 25-03-17 update stripped it all apart checked and cleaned everything all the bearings seals spacers the lot all spotless , took sprocket off its as flat as a flat thing can be and is brand new jt make cleaned the hub carrier assembled everything with a light coat of grease where needed , put the wheel back on tightened up everything one thing i did notice is the spindle torqued up a lot easier none of the endless tightening you get i can only assume it was the old grease and crud getting squashed that made it feel this way i spun the back wheel by hand couldnt see any run out witch i could before spinning by hand so started it up put it into second let the wheel spin and the run out is now almost gone to the point i am happy with it so the only thing i can think of was the old grease and crud causing things not to sit strait Re: rear sprocket run out - vinnyb - 25-03-17 Cool :thumbup Re: rear sprocket run out - daviee - 28-03-17 Update took it out for a good run about 80 miles checked it when i got it back and the run out is back still can't find any play in anything so i have a replacement sprocket carrier and new. Bearing on its way to see if that stops it the sprocket carrier turned up when you soon it their is absolutely no run out at all so here's hoping |
