Heated Grips - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Heated Grips (/showthread.php?tid=77739) |
Heated Grips - Koreanbaz - 21-03-17 my new to me Fazer has heated grips. That weren't working. But on further inspection the fuse was removed. I also noticed that it's just supplied direct from the Pos and Neg on the battery. So I imagine a battery drain caused the fuse removal. I fitted a fuse, and they do work on all four settings Oxford system. So where do people generally take the positive from to prevent a flat battery. Re: Heated Grips - unfazed - 22-03-17 Use a relay to switch on to power to them only when the ignition is on, as this will turn them off when the ignition is turned off. No fear then of flattening the battery that way as you cannot walk away leaving them on. Take the supply for the relay from somewhere like the horn or brake light circuits and run the power for the heated grips through the relay contacts via a fuse to the battery positive. Re: Heated Grips - mtread - 22-03-17 Which version of the Oxford grips is it? If it's v8 the controller has an 'automatic off' facility to stop it draining the battery. Works fine. Re: Heated Grips - celticdog - 22-03-17 From the horn Re: Heated Grips - VNA - 22-03-17 Just use one of the spare switched lives in the fuse box. See the guide to fitting heated grips on the old forum here - http://fazerowners.yuku.com/topic/5650/HOWTO-Fit-your-heated-grips-PICS-BACK#.WNJd26LfNaQ Scroll down the page to see the photos I added on how to access the spare switched live. Hook up to that using an inline fuse. Re: Heated Grips - Skippernick - 22-03-17 :agree easy as pie. Re: Heated Grips - celticdog - 22-03-17 (22-03-17, 12:23 PM)VNA link Wrote: Just use one of the spare switched lives in the fuse box. That's a good find from the old forum :thumbup Re: Heated Grips - BBROWN1664 - 22-03-17 from the rear brake light switch. Re: Heated Grips - Koreanbaz - 22-03-17 (22-03-17, 12:23 PM)VNA link Wrote: Just use one of the spare switched lives in the fuse box. Excellent awesomeness ???? Re: Heated Grips - Koreanbaz - 23-03-17 As per the instructions on here, I even wired them to the suggested place and soldered ![]() cheers for the info 8) |
