Indicator problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Indicator problem (/showthread.php?tid=77714) |
Indicator problem - Dudeofrude - 19-03-17 So I fitted my new L.E.D tail light this morning and found out when I got to work that my indicators aren't working? I tested them by just plugging the light in first and they were fine. I can disconnect the new light and they still don't work. If I turn the bike off then back on the right hand side will flash and work fine but as soon as I try to put on the left or the hazards then they both stop working. I haven't touched the wiring at all as the new light is just a plug and play kit thar goes into the existing light socket. I did strip all the back end of and undid the undertray and tail tidy so I'm thinking ive have dislodged something or possibly caused a wire to break? Any ideas of anything to try before I strip her apart again tomoz? Re: Indicator problem - Dudeofrude - 19-03-17 Fixed it. Some foc face had joined the right hand indicator with 2 bare spade connectors covered in a single layer of electrical tapeĀ and I think with my jostling about earlier they had managed to be touching. Least it was a quick cheap fix ? |
