Piston Ring Compressor size? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Piston Ring Compressor size? (/showthread.php?tid=77694) |
Piston Ring Compressor size? - Agentorange - 17-03-17 Hello there just wondering if anyone could give me the piston ring compression tool size that id need for the 600cc pistons ? Also do i need 4 ? or can i get the job done with 2 ? Any help would be mucho appreciated Cheers Re: Piston Ring Compressor size? - daviee - 17-03-17 dont need any if your handy with your nails and small probes Re: Piston Ring Compressor size? - Agentorange - 17-03-17 Ive tried that system a single cylinder but didnt think it was possible on a 4 cyl Re: Piston Ring Compressor size? - robby boy - 17-03-17 I saw somewhere someone using a 2 litre coke bottle cut to fit the piston rings and split, then clamped over the piston rings using cable ties, once the pistons were in the bores cut the cable ties, job done. Re: Piston Ring Compressor size? - Disorderlypunk - 18-03-17 an old trick when need be has been to use jubilee clips 62mm bore x PIE = cornish pastie or (62 x 3.141592653589 = just short of 195mm ) with a jubilee clip you dont mind wasting a couple of quid once done and they tend to come in packs of 2 at least - im sure its a 62mm bore but im not pulling my engine to check Re: Piston Ring Compressor size? - Bretty - 18-03-17 As said, you don't need one on the fzs600. As the bores have a slight taper, just go steady, compress the rings with your fingers, 2 cylinders at a time. An extra pair of hands helps to stop the crank turning. Re: Piston Ring Compressor size? - Agentorange - 18-03-17 (18-03-17, 01:39 AM)Disorderlypunk link Wrote: an old trick when need be has been to use jubilee clips Thats actually a cracking idea :thumbup Thanks for the help chaps! |
