Throttle cable slow to snap back - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Throttle cable slow to snap back (/showthread.php?tid=77648) |
Throttle cable slow to snap back - petters - 12-03-17 Hello. I just had my bike apart to sandblast my frame and paint it. I put in the carbs today, but not shure if i got the wire routing right.. the handle is a bit hard to turn around and snaps back a bit slow. Somebody have pictures of their routing? Re: Throttle cable slow to snap back - Fazerider - 12-03-17 Pages 48 and 49 of the manual (in the downloads section) show the routing fairly well. Re: Throttle cable slow to snap back - celticdog - 13-03-17 I had this,turns out the bar end weights and the throttle assembly at the handlebars where a bit to tight. If they're all squeezed to close together they can rub slightly, worth a check. Re: Throttle cable slow to snap back - petters - 13-03-17 Yes I did loosen it a bit up yesterday,it got better but not 100%. Re: Throttle cable slow to snap back - SutherlandFZS600 - 20-03-17 Check your routing of cables/wires etc then if okay check your free of throttle using manual. Be sure to check adjustment of cables at carb end as if you don't have it adjusted there correctly you will get sticking and slow throttle operation. If done all that then maybe cables them self oil/replace Re: Throttle cable slow to snap back - Bretty - 21-03-17 Check where the outer cables attach to the carbs. You might need to slacken one of the outer cables just a little. |
