tail tidy - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 8 / FZ8 (https://foc-u.co.uk/mybb/forumdisplay.php?fid=76) +--- Thread: tail tidy (/showthread.php?tid=77644) |
tail tidy - KENT62 - 12-03-17 Has anyone fitted an R&G tail tidy, that you can use the original indicators with? Are they simple to fit? Re: tail tidy - Trickie - 17-03-17 Fitting is straightforward unless you have a givi top box rack (Like Me!) Then you have to bend the attaching plate a bit so indicators don't clash with rack. Re: tail tidy - KENT62 - 17-03-17 Tricky, thanks for that. I have a Yamaha rack so I'll see how it goes. Re: tail tidy - KENT62 - 21-03-17 If anyone decides to get one it would be worth a message on fitting. Took me 3 hours but I'm not the best mechanic in the world! I had to take off a lot more bits than expected. Re: tail tidy - Stormbringer - 15-11-19 Ive got one on order so will let you know. Re: tail tidy - Stormbringer - 19-11-19 ![]() ![]() The bike allready had one fitted . Re: tail tidy - celticbiker - 21-11-19 First thing I did was put the rear end back to standard. Don't like the look of the tail tidy. Re: tail tidy - Stormbringer - 22-11-19 I didnt get the standard rear with mine but may buy one and try it .
Re: tail tidy - Stormbringer - 22-11-19 Ive just won a complete original rear end on Ebay .
Re: tail tidy - celticbiker - 22-11-19 Picked up a brand new one on the Bay for 20 quid. Might want to get a couple of huggers in too when you see them cheap. I've had one break every year but I do cover a lot of miles, around 500/week. Re: tail tidy - Stormbringer - 26-11-19 I removed the R and G tail tidy last night .The longest part is the wiring .I took of the four bolts holding the tail tidy from under rear seat ,the rear seat surround bodywork (clips and bolts) ,both grab handles (2 bolts each), the rear under tray(8 trim clips ) .I also removed the steel bridge at the front of the rear seat from the sub frame (4 small Bolts ) to make access to ther light and indicator bullet conecters easier. Then disconected the indicators,number plate light and tail light . ![]() ![]() Re: tail tidy - celticbiker - 26-11-19 What do you think, better or worse? Re: tail tidy - Stormbringer - 26-11-19 Better but I may fit some LED indicators . Re: tail tidy - celticbiker - 26-11-19 I'm gonna fit the led headlight bulbs back in when I get chance. Re: tail tidy - Stormbringer - 26-11-19 Yes on my list as well . Also been trying to find a r LED rear light unit without indicators . Re: tail tidy - Stormbringer - 27-11-19 Ive just bought a new 2006 R6 rear plate holder(ebay £20 delivered) and have got the LED indicators .Just waiting for the adaptor plates for the indicators to arrive. |
