Fzs600 engine removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fzs600 engine removal (/showthread.php?tid=77593) |
Fzs600 engine removal - Agentorange - 07-03-17 Hello there Just wondering if the cards and airbox need to be removed to get the motor out? Re: Fzs600 engine removal - Fazerider - 07-03-17 Yes, the carbs need to come out. In order to do that the airbox needs to be loosened and slid back, but you don't need to take it out. Re: Fzs600 engine removal - Agentorange - 07-03-17 Ah cheers for the reply
Re: Fzs600 engine removal - Agentorange - 07-03-17 Does the motor come of of the left or right side? It's being a proper pig If I try to take it out of the right hand side the oil filter port doesn't have room And the left side doesn't seem right Haside to be the most difficult engine to remove Re: Fzs600 engine removal - Agentorange - 07-03-17 Does the motor come of of the left or right side? It's being a proper pig If I try to take it out of the right hand side the oil filter port doesn't have room And the left side doesn't seem right Haside to be the most difficult engine to remove Re: Fzs600 engine removal - Fazerider - 07-03-17 Yes, it does come out of the right hand side of the frame. I've always had to take the oil filter off, but it does wriggle out OK. Re: Fzs600 engine removal - Agentorange - 07-03-17 Cheers, I've taken the filter off but where it threads on is tight by the frame Re: Fzs600 engine removal - Bretty - 07-03-17 Take the oil filer off AND the housing behind it!! It's got a big nut in the middle and I don't think it's possible to get the engine out with it still on! Re: Fzs600 engine removal - Bretty - 07-03-17 Get a trolley jack under the engine. Pump the engine up, slide/wiggle it onto the frame, reposition jack under engine outside the frame, then wiggle the engine onto the jack and roll the engine away. It's not that tricky, I can get the engine out in under an hour.. Putting it back in is the pig and can take me 3 or 4hours - reconnecting throttle cables, carb rubbers, working out all the cable and pipe routing, etc... It's all worth it, for the satisfaction of firing the bike up for the first time once all the work is done. Re: Fzs600 engine removal - Agentorange - 07-03-17 I got it out in the end, what a cu#t that was! :eek Managed to get it out with the oil filter housing on but will definitely take it off to put it back in! Cheers for the help and advice so far lads |
