Plugs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Plugs (/showthread.php?tid=77554) |
Plugs - Disky - 04-03-17 this will explain why the bike was a bit slow of the mark..lol Always check serviceable items when you buy a new steed Re: Plugs - daviee - 04-03-17 they dont look that bad apart from the corrosion Re: Plugs - JoeyMcEssex - 05-03-17 At least you know they weren't fake knock offs from China they didnt start appearing till 2005 :lol Re: Plugs - bikemad - 05-03-17 Pfft a wire brush & bit of emery paper they'll be fine ? Re: Plugs - darrsi - 05-03-17 It's the spark that counts. Ends look okay, but corrosion is caused by water sitting around the plug area, which would suggest your drainage holes could be clogged up. I'd get an airline and blow air into the holes in the middle of the engine fins and see if it unblocks anything. Also blow any crud away from around the spark plug area on top. Re: Plugs - Disky - 05-03-17 (05-03-17, 01:14 PM)darrsi link Wrote: It's the spark that counts. Ends look okay, but corrosion is caused by water sitting around the plug area, which would suggest your drainage holes could be clogged up. Done
