Givi/Kappa tankbag ring needed - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Givi/Kappa tankbag ring needed (/showthread.php?tid=77469) |
Givi/Kappa tankbag ring needed - Reyno - 23-02-17 Anyone know of a Givi/Kappa tankbag ring that will fit a Gen 1 Thou ? They do not list one on their site! Thanks. Re: Givi/Kappa tankbag ring needed - mr self destruct - 23-02-17 ![]() The 600 will fit if the two rear bolts are 60mm apart and the front one is 75mm forward of them. Re: Givi/Kappa tankbag ring needed - Reyno - 23-02-17 Thanks for that msd! I will check it out. Reyno. Re: Givi/Kappa tankbag ring needed - mr self destruct - 23-02-17 I've totally redone my post, as rather than take a chance buying a ring, just measure your filler cap! Re: Givi/Kappa tankbag ring needed - ninjabika - 25-02-17 hi ive just bought the BF05 hopefully itll fit, its for most yams, if not ill drill it to suit martin Re: Givi/Kappa tankbag ring needed - Lez72 - 26-02-17 I too was pondering over which Givi tanklock ring to order for my Fazer 1000 and also noted that they didn't list a fitment on the Givi website. However, I checked the aj sutton website and discovered that the same fuel cap assembly is listed for multiple bikes (as you would expect) that are listed under the BF05 application so I can't see a reason why it wouldn't fit. I've pulled the trigger on one anyway so expect it to arrive later this week. I will then provide an update. Regards Re: Givi/Kappa tankbag ring needed - Lez72 - 04-03-17 I can confirm that the BF05 tank ring is the one to go for on the Gen 1 Fazer thou :thumbup :thumbup Re: Givi/Kappa tankbag ring needed - Reyno - 11-03-17 Excellent, thanks to all. |
