"HELP" Spark plug snapped off in head leaving ceramic in situ - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: "HELP" Spark plug snapped off in head leaving ceramic in situ (/showthread.php?tid=77408) Pages:
"HELP" Spark plug snapped off in head leaving ceramic in situ - Gabrael72 - 16-02-17 Hello fellow foccers, I need to ask your advice! My beloved 2000 plate fzs has been misfiring of late so I decided to start by swapping out the plugs, the off side inner most would not budge, even after heating up, later spraying with penetrating oil and leaving for a week, and culminating in giving it one last try today and it shearing leaving the bottom half of the ceramic and the metal threaded part still in the head! My local bike garage has costed me around £600 for engine to be removed, head split (to clear out any left over ceramic) new gaskets and sundries, rebuilt and put back in bike, does anyone know any tips or tricks or do I have to bite the bullet and murder the wife to get my hands on her insurance? ? Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Graham53 - 16-02-17 Have a look at this post from a fellow foccer that had the same http://foc-u.co.uk/index.php/topic,21782.msg251736.html#new Don't know where you are but maybe the bods that helped with his are a possibility or it might steer you in the right direction Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Gabrael72 - 16-02-17 Thank you so much, unfortunately I'm at the opposite end of the country to them, but i may give them a call to see how exactly they did it! Once again, thanks. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - His Dudeness - 16-02-17 Haven't come up against that problem myself but I know you can get extractors that are reverse thread and as you drill down into the plug it grips and unscrews. If you don't fancy doing it you should be able to find a bike shop that would have a go at extracting it. If it was me I'd probably take the head off. It's not as difficult as it sounds if you've got reasonable skills with tools and can follow a manual. The trickiest bit is getting the exhaust off without shearing a stud. You need a low end torque wrench and a new head gasket Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Bretty - 17-02-17 I've had this issue on an old donor engine I bought. So there is no ceramic left in the remainder of the plug, it's dropped into the cylinder? Well you can't run the engine with ceramic in it, it'll damage your valve seats. You must have snapped it off quite low down to do that. However, if there is no ceramic in the middle of the plug, it's a lot easier to drill out and then in theory you might be able to insert a tube into the hole and hoover out any bits. Someone will probably tell you you can do that with the engine in situ, but it's a pig of a job. For me it's an engine out job, but not an engine rebuild, just some drilling. If there is still ceramic in the middle of the plug, it's impossible to drill. sometimes you can blow it out the top of the plug just by running the engine, Then you just need to reverse drill out the remainder of the plug. Else punch the ceramic down into the engine and follow step one. Personally, I would pull the engine out, which can be done with basic tools, you just need a big socket for the sprocket nut, trolley jack and a Haynes manual. and hope your exhaust studs are in good nick, but no dramas, you're pulling the engine out anyway. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Bretty - 17-02-17 If you want to save money, a decent donor engine is about £250/300. Else take the engine out yourself and take it to the garage in the boot of a car. It should only take half a day of labour and a new head gasket to sort out the plug and remove/refit the head. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - red98 - 17-02-17 As "HIS DUDENESS" head off...no need to remove engine, head can be removed with engine in frame ![]() Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - darrsi - 17-02-17 Bit confused here, how can ceramic drop into the cylinder head, it won't get past the tip of the plug? Am i right in thinking that the plug has somehow sheared off just below the head of the spark plug bolt, so the threaded part is still in place? Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Bretty - 17-02-17 If the ceramic is in one piece it won't get past the tip. But if it has crumbled when it sheared off or while you try to get it out, it'll go past. I couldn't get the ceramic bit out of mine, so had to whack it down into the engine so there was something I could drill into. I've got a lot of respect for anyone that can replace a head in situ, let alone get an old spark plug out as well. It is possible, but not for me. I found it all difficult enough with the engine out - sorting the timing, torquing up all the screws and getting the cam chain guides sorted. You need some patience, small hands and the right tools in situ. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Gabrael72 - 17-02-17 Guys thank you so much for your collective expertise, think I'm going to go down the dropping engine out myself route and having a look first, if I come across any problems I know where to come for advice?? Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Ruby Racing - 17-02-17 (17-02-17, 02:56 AM)Bretty link Wrote: If you want to save money, a decent donor engine is about £250/300. This was my first thought too. Or just get a head. One on eBay at the moment for £90 CLICK HERE But if you can't fix it with engine in situ then I'd drop the motor and have a go at extracting the remnants then. If that failed then I'd probably just get a complete motor and save yourself the hassle of changing the heads over. Dropping a motor is not as hard as it sounds. Although it does help to have at least another pair of hands to help. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Bretty - 17-02-17 A new head sounds like a good idea... but you'll need to regrind your valves in, you'll also need a valve spring compressor. Then you have to fit the head, measure the valve clearances... then take it all apart again to fit new shims. Have a look on the foc-u facebook page. A few bikes are being broken. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - davebike - 17-02-17 Delt with this a couple of times on customers bikes ! I been able to extract the centre electrode / and ceramic by pulling with needle nosed plyers adn drillin if required Then used lots penertrating oil over 24hours Then easy out and clean thread with a tap Then all plugs out spin the engine a fair bit to spit out any debris not for the faint harted but if it fails it engine out and either another engine of head off ! Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - His Dudeness - 17-02-17 Another option is a flute extractor. You hammer it into the spark plug and it grips and you turn it out. You'd need a long one to reach the plug. ![]() Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Dinger1962 - 17-02-17 Number for PARTSVILLE BARROW IN FURNESS is 01229 813824 speak to HARRY-- sorted mine having explained the process its a job i would tackle myself next time--cheers stu Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Dinger1962 - 17-02-17 Oh while i remember i blew the remains of ceramic/electrode out by running on 3-cheers Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Gabrael72 - 18-02-17 WOW, really foccers I am humbled by your help, I will keep you posted, keep your fingers crossed ?? Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - darrsi - 18-02-17 (18-02-17, 12:35 AM)Gabrael72 link Wrote: WOW, really foccers I am humbled by your help, I will keep you posted, keep your fingers crossed ?? Gotta be done fella, we've all had our ups and downs over the years, may as well just help each other the best we can. ![]() Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - Carter - 18-02-17 Heat could be your friend here. Small oxy or jewellers torch . Plug may need heating /cooling a few times to expand and contract it enough with a bit of diesel or plus gas between heatings. A steady hand and fuel moved to a safe place recommended. Re: "HELP" Spark plug snapped off in head leaving ceramic in situ - bikemad - 18-02-17 If your really stuck I've got a head from an engine which due to sprocket been welded on its going to be dismantled for spares. I have snapped a plug once on a 500gs leaving the metal thread behind,luckily was outer plug & room (just) to get a drill in there so know how it feels. |
