Changing the bar's - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Changing the bar's (/showthread.php?tid=77354) |
Changing the bar's - Rabbit22 - 06-02-17 Hi all. Well I'm looking at changing the bar's on my fz6 05 plate to a set of ultra low renthal's, but remember reading somewhere that I would need some slight modifications. Do any fz1 bars fit as they look like they are flat bars? Re: Changing the bar's - Graham53 - 06-02-17 When I changed the bars on my foxeye to renthals I had to drill small holes in the bars for the switches and levers as they have locating pins on them, I assume that FZ6 is the same , I do know some just file off the pins in the handle bar switches and levers which is a bit irreversible and depending on how the FZ6 bar end weights mount you may need to get renthals ones or find a way to fit the oe ones. I'm not sure about the fz1 bars as again the locating pins might be in a different position and you're back to the drill holes or file pins conundrum. Re: Changing the bar's - Rabbit22 - 07-02-17 Cheers Graham53, what renthals did you go for? I was looking at ultra lows unless their is a set which are even flatter |
