Steering Head Bottom Bearing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Steering Head Bottom Bearing (/showthread.php?tid=77299) |
Steering Head Bottom Bearing - Andy1970 - 29-01-17 Hi Everyone, Just wanted to share this, which I found in Homebase today. It's a furniture leg, it cost me around four quid and it's exactly the right size to install the bottom head bearing onto the shaft. It had a plastic foot on the bottom which you need to remove, and the top is a metal plate perfect for hitting with a hammer. It also comes in a variety of colours. :lol Andy Re: Steering Head Bottom Bearing - Bretty - 29-01-17 Installing them is the easy bit and can be done with a variety of persuasion sticks (hammers). ;-) Getting the foccers out/off in the first place is the tricky bit. I think I pretty much used up all my swear words when I did mine. Re: Steering Head Bottom Bearing - Andy1970 - 30-01-17 Yeah, I took mine to a local mechanic who was willing to hit it much harder than I was. mash He got it off in about a minute and charged me the price of a drink.
Re: Steering Head Bottom Bearing - joebloggs - 31-01-17 I drifted the lower bearing out with a length of 10mm stainless round bar, no taper, three or four taps with a rubber mallet, job done, re seating the new one was a different matter, bastard took bloody ages even after leaving it in the freezer for a couple of days Re: Steering Head Bottom Bearing - Andy1970 - 31-01-17 Yeah, getting the outer races into the headstock was more difficult than I'd expected. I'd planned to draw them in using a threaded bar and a couple of large washers that I'd ground to size. That worked, but only by winding on as much tension in the bar and washers as I could, and then tapping the washer with a hammer, then re-tightening the bar and repeating. Re: Steering Head Bottom Bearing - Jules-C - 31-01-17 Replaced my head bearings with taper roller ones a while ago but the new bearing shells don't project as far out as the original ball ones so not sure there's enough lip to be able to drift them out |
