Carb Idle adjuster difficulty - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Carb Idle adjuster difficulty (/showthread.php?tid=77292) |
Carb Idle adjuster difficulty - Graham53 - 28-01-17 i thought I'd have a go at Ivan's TPS adjustment today However I can't get the idle screw adjuster to set the idle above 1800 rpm :'( no matter how much I turn it It will allow me to return back to normal idle speed but when blipping the throttle after the revs sort of hang around a bit at 4000 and drop back slowly. Anyone got a clue why I can't get the idle above 1800. Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 Why you trying to idle it above 1800? I'm only asking because today I was trying to get my pissing TPS sorted so increased my idle from around 1000 to the recommended 1250-1350 (again I found the screw difficult to turn by hand) in the end I couldn't get the TPS to read anything but 10000 So far I have had new plugs, carbs cleaned and balanced as well, I did briefly see the correct 5000 reading but it then shot up to 10000 so I just moved it back to the position it was in and tightened screws, bike seems to run OK so fuck it. Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 The Ivans method of setting the TPS requires setting the idle to 3800 rpm before adjusting the TPS http://www.cartestsoftware.com/fz1/throttlepositionsensoradjustment.html Check this link and scroll down to the addendum Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 BRI I will try mine again tomorrow using this info
Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 *brill I've supped a few ales and struggling to type, maybe I shouldn't try this tomorrow
Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 Mmmmm it only suggests that method for re-jetted bikes and not stock setup. Unfortunately I don't what mine is because the fuckwit who owned it before me only rode it 4 times in two years and two of those times it ended up on the deck. Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 So I doubt he knows which way is up never mind the setup of the bike Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 (28-01-17, 09:05 PM)darrenc link Wrote: BRI I will try mine again tomorrow using this infoHope you have better luck than me :'( Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 Me too, I'm all for kicking the bike in its nuts, I should have bought another hornet, that little pocket rocket never let me down. Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 im sooo frustrated with mine at the moment maybe I should've got one of them too :'( Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 Maybe we can trade both our bikes in and get one good bike, im a weekly commuter but its all your at weekend haha
Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 (28-01-17, 09:25 PM)darrenc link Wrote: Maybe we can trade both our bikes in and get one good bike, im a weekly commuter but its all your at weekend hahaThat sounds like a plan , I was 5 minutes from pouring petrol over it today and claiming the insurance Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 Haha shit just realised this is for the FZ1 I don't even have that bike, I'm off to bed
Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 (28-01-17, 09:32 PM)darrenc link Wrote: Haha shit just realised this is for the FZ1 I don't even have that bike, I'm off to bedYou know the FZ1 is American for fazer 1000 Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 I don't have a Fazer 1000 either
Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 (28-01-17, 10:04 PM)darrenc link Wrote: I don't have a Fazer 1000 eitherSorry bud thought you did as is the 1000 forum. 600 TPS should be easy enough to set up , do the check , disconnect TPS turn on ignition ,code will read 0k 5k or 10 k undo TPS move until it reads 5k , tighten it up unless that's what you've been doing then I'm stumped or post thread in 600 section Re: Carb Idle adjuster difficulty - darrenc - 28-01-17 Told you I was pissed haha, yeah tried all the usual, ignition on, remove TPS connector and connect it back up, it reads 10000, I then undo bolts swivel it about a bit and it doesn't budge for shit, tightened it back up and left it, swore at it a few times then went in house to drink ale. Re: Carb Idle adjuster difficulty - Graham53 - 28-01-17 Sorry mate can't do anymore than say enjoy the ale or put post in 600 section or search TPS probs |
