How do I get this bit off!? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: How do I get this bit off!? (/showthread.php?tid=77230) |
How do I get this bit off!? - birdyboyuk - 16-01-17 I need to get to the wiring at the rear of my bike, but my fat fingers and hands have only such a limit! I noticed the top of the fairing, there is a kind of cut out that looks like it would slide out giving me more access, but buggered If I know how to remove it!? Any ideas people? I did unscrew two screws from underneath that were at an angle, but nothing...I don't want to risk snapping it or anything... ![]() Sorry for the big pictures! :eek Can anyone please help? :rolleyes Re: How do I get this bit off!? - gingernut - 16-01-17 It looks like you have to take the rear side fairings off 4 screws / nuts , its very easy ...... ta Ginger Re: How do I get this bit off!? - birdyboyuk - 16-01-17 (16-01-17, 05:09 PM)gingernut link Wrote: It looks like you have to take the rear side fairings off 4 screws / nuts , its very easy ...... Ok, I'll give that a go...this is all new to me. My expertise is IT, not mechanical stuff! ![]() It just kinda looked that this part would slide out, but it doesn't budge...will let you know how it goes! Re: How do I get this bit off!? - unfazed - 16-01-17 Once all the screws/bolts are off you need to pull it apart slightly and back. There are 6 screws/bolts in total, front underneath ones are plastic. Unscrew the plastic and lever out the plastic retainer Re: How do I get this bit off!? - BBROWN1664 - 16-01-17 If you are talking about the plastic section above the rear light, you take each of the rear side panels off and then it will come off. It does not slide out. IIRC, there are screws or clips holding it in which can only be accessed once the sides are off. To get the sides off, you will need to remove the rack first. Re: How do I get this bit off!? - tommyardin - 16-01-17 No one mentioned the big hammer :eek Re: How do I get this bit off!? - daviee - 16-01-17 oh no you had to mention the big hammer :eek
Re: How do I get this bit off!? - unfazed - 16-01-17 (16-01-17, 05:34 PM)unfazed link Wrote: Once all the screws/bolts are off you need to pull it apart slightly and back. There are 6 screws/bolts in total, front underneath ones are plastic.Posted it before I finished it :rolleyes As Brown1664 says When the whole unit is out turn it over and undo the screws/clips to take it all apart. Re: How do I get this bit off!? - mtread - 17-01-17 Quote:My expertise is IT, not mechanical stuff! Have you tried switching it off, and switching it back on again ?
Re: How do I get this bit off!? - celticdog - 17-01-17 (17-01-17, 12:11 AM)mtread link Wrote:Quote:My expertise is IT, not mechanical stuff! :lol you could also try F1 or ctrl + alt + Shift Re: How do I get this bit off!? - Bretty - 17-01-17 I struggle with mine when checking the wiring to the lights and indicator. I think I damaged mine in the end. Just go steady with it and don't be tempted to force it as the tabs and bits holding it together are pretty brittle. Re: How do I get this bit off!? - Jamieg285 - 17-01-17 Yes, the flap only comes out if you've got the whole assembly is out, which kind of defeats the object of removing it at that point. I can't remember the exact details from when I took mine off, but there were four bolts that hold the grab rail on, then 2 or four more. It was all pretty easy to work out. Re: How do I get this bit off!? - birdyboyuk - 17-01-17 Thanks all...will give it a go this weekend and let you all know how I get on! Re: How do I get this bit off!? - tommyardin - 17-01-17 (16-01-17, 07:34 PM)daviee link Wrote: oh no you had to mention the big hammer :eek Sorry! me and my BIG mouth Re: How do I get this bit off!? - tommyardin - 17-01-17 (17-01-17, 12:54 AM)celticdog link Wrote: [quote author=mtread link=topic=21677.msg250102#msg250102 date=1484608295] :lol you could also try F1 or ctrl + alt + Shift [/quote] F5 if he is using PowerPoint Re: How do I get this bit off!? - birdyboyuk - 22-01-17 Got it all sorted! ![]() A lot easier than first thought! The bit that appears to slide off is screwed in place, so if I was to leave them out, then it would do what I thought it would, however, no idea how secure that would be, so have left as is. I don't know what I was worrying about! :lol |
