Spark Plugshi - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Spark Plugshi (/showthread.php?tid=77224) |
Spark Plugshi - Scotfaze - 15-01-17 evening all, Decided to tackle the servicing myself, plugs,oil change,coolant change etc.I have removed the radiator to get rid of th AIS system as well.Problem with that,but that's in another post. Problem is I can't get the bloody spark plugs out, I've unscrewed no1 with Halfords spark plug remover with the rubber bit inside,but it's just not pulling the plug out.Ive heard the plug wrench from the toolkit works well,but I don't have one.Does anyone have one I could buy or borrow. Or does anyone have a better idea, access is easy with radiator and AIS removed. Re: Spark Plugshi - ogri48 - 15-01-17 If your anywhere near the Forest of Dean your welcome to borrow me toolkit feller.. Re: Spark Plugshi - Scotfaze - 15-01-17 Thanks for the offer Ogri48... but I'm up in the Glasgow area.. Re: Spark Plugshi - ogri48 - 15-01-17 No worries. You tried a magnetic screwdriver or a bit of tube just the right internal diameter to push over the tip of the plug and grab it? Re: Spark Plugshi - Fazerider - 15-01-17 Turn it upside down and shake.
Re: Spark Plugshi - Scotfaze - 15-01-17 ogri48, I've tried the clear hose from my scotoiler it's a tighish fit,but can't get a good grip on it.I'll try the magnetic approach. Fazerider.......if only..??? Re: Spark Plugshi - tommyardin - 15-01-17 Might sound silly but the plugs in the Fazers are long reach plugs have you completely unscrewed it? Re: Spark Plugshi - tommyardin - 15-01-17 Also it's worth making sure there is no dirt or crud in the plug 'well' before removing the plug or you might get dirt falling inside the cylinder head. Re: Spark Plugshi - PieEater - 15-01-17 I shove some bluetack up the socket, works well. Re: Spark Plugshi - tommyardin - 16-01-17 (15-01-17, 10:30 PM)PieEater link Wrote: I shove some bluetack up the socket, works well. Seems very resonable Re: Spark Plugshi - PieEater - 16-01-17 (16-01-17, 12:11 AM)tommyardin link Wrote: [quote author=PieEater link=topic=21671.msg250003#msg250003 date=1484515851] Seems very resonable [/quote] Also works well at holding the new plugs in place when fitting them down the head. I don't have the OEM spark plug tool but find a combination of 3" and 6" extensions along with a universal / knuckle joint works OK. Re: Spark Plugshi - Tmation - 16-01-17 :agree I use the same as PieEater, never had an issue. When I first changed the plugs I wondered what all the fuss was about. Re: Spark Plugshi - Scotfaze - 19-01-17 Thanks guys for all your suggestions, blue tac got them out then in no bother.. |
