Clutch shaft roller bearing numbers? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Clutch shaft roller bearing numbers? (/showthread.php?tid=77138) |
Clutch shaft roller bearing numbers? - silverfz - 26-12-16 Hi does anyone know the bearing numbers for the two roller bears that the clutch arm lever rod goes through? the two in the clutch cover housing. thanks Re: Clutch shaft roller bearing numbers? - DekF - 26-12-16 Part numbers are in this link: http://www.cmsnl.com/yamaha-fzs1000-fzs1000c-2002-2-usa-california_model11009/partslist/C-03.html#results Re: Clutch shaft roller bearing numbers? - silverfz - 27-12-16 Thank you
