Mivv exhaust bolt - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Mivv exhaust bolt (/showthread.php?tid=77105) |
Mivv exhaust bolt - Kenbob - 18-12-16 has anybody successfully installed a mivv exhaust using the m8 bolt supplied, if so what wizardry did you employ, I can't get it to bite the nut on the other side of the footrest,it's just not long enough. Poor measuring mivv personnel. Re: Mivv exhaust bolt - Graham53 - 19-12-16 :useless Post up a pics of the problem or of the bolt you've got against the standard fittment or use that instead ?? Re: Mivv exhaust bolt - Kenbob - 19-12-16 Bolt that came with the exhaust is too short, it's m8 70mm, it should be m8 80mm. There is no way a 70mm bolt gives enough thread on the other side of the footrest hangar for the bolt to bite. Didn't post pics as I was too mivved off. See what I did there. Re: Mivv exhaust bolt - BMCfaz - 20-12-16 I wonder if it's pot luck on the supplied bolts, the one with mine was about 30mm longer than needed. Re: Mivv exhaust bolt - Graham53 - 20-12-16 (20-12-16, 12:22 AM)BMCfaz link Wrote: I wonder if it's pot luck on the supplied bolts, the one with mine was about 30mm longer than needed. That is sooooo Italian , I can imagine it in the mivv factory someone packing the boxes just throwing bolts in willy nilly :lol " fucking engleesh they vote a to leave a the eu , we show eeeem we give eeem the wrong a bolt " I know , Piss poor way to attempt an Italian accent but it's the best I could do Re: Mivv exhaust bolt - Kenbob - 20-12-16 Sounded Greek in my head that did. Re: Mivv exhaust bolt - teecee90 - 21-12-16 Same for me - if anything a bit too long.
Re: Mivv exhaust bolt - Kenbob - 23-12-16 That's how mine looks now with the 80mm bolt, stuck a nylock nut behind the first nut though for belt and braces. |
