Chain monkey - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Chain monkey (/showthread.php?tid=77102) |
Chain monkey - Kenbob - 16-12-16 does anyone use a chain monkey to set the chain slack. If so does it give the correct slack. Re: Chain monkey - fazerscotty - 16-12-16 I do it myself - haven't found a trustworthy monkey yet............. :rollin :rollin :rollin (Sorry, just had to..) Re: Chain monkey - PieEater - 17-12-16 From personal experience if properly maintained a chain will need very little adjustment once it has gone through the initial stretching process from new. So it's just a question of measuring rather than adjusting the slack to confirm everything is OK. So unless I am missing something this seems to be a solution to a problem that doesn't exist and actually makes a simple job like adjusting the chain more complex than it needs to be :\ As a suggestion posting your question in the General section of the forums would give you a wider range of people who may have had experience of this product. Re: Chain monkey - Kenbob - 17-12-16 I posted in this section merely because the fazer thou runs a slacker chain than the 600 and just wondered if the chain monkey gave the correct chain slack as per the monkey setting. Re: Chain monkey - Andy W - 23-12-16 (16-12-16, 08:59 PM)fazerscotty link Wrote: I do it myself - haven't found a trustworthy monkey yet............. :rollin :rollin :rollinDOH..! :rolleyes You could buy one of these, I guess they have self adjusting chains.......
Re: Chain monkey - Rob R - 05-02-17 Sorry to resurrect this but yes, I use a chain monkey and no- you can't trust the instructions to give you the perfect amount of slack. Once you've got it calibrated though it's very reliable with repeatable results. Is it worth £24?? maybe if you've got several bikes. Rob Re: Chain monkey - red98 - 05-02-17 Not seen these before....how do they work ?...ROB R.....you got any piccies ? Re: Chain monkey - PieEater - 05-02-17 https://youtu.be/uoEh2Qg50yc Re: Chain monkey - red98 - 05-02-17 Mmmmmmmm....not sold on that....dosnt mention anything about tight spots.....just as easy to put a tape measure behind the chain .......me , ill carry on doing it by eye
Re: Chain monkey - Rob R - 05-02-17 In the instructions it does say that if there is a tight spot you should use that point to set the slack. I must admit I still double check with a steel rule. Mine was a well meant xmas pressie so I can't complain. Rob |
