foccer font of knowledge - mirror hanging - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: foccer font of knowledge - mirror hanging (/showthread.php?tid=77050) |
foccer font of knowledge - mirror hanging - HarryHornby - 04-12-16 Hi Guys, Just got a mirror to go over the fireplace, it's not mega heavy but certainly more than a picture of the same size, it's 94cm X 68cm. It's already got a doubled up heavy gauge cord to hang it from. I've never hung anything this heavy before so my question is, what fittings and how many? My initial guess is 2 brown rawlplugs with screws placed about 10cm either side of the centre line. Would that be ok? would one be ok? I'm guessing a large picture hook nailed into the wall certainly wouldn't be up to the job. Re: foccer font of knowledge - mirror hanging - Grayo - 04-12-16 I would use something like this. http://www.ukpictureframingsupplies.co.uk/heavy-duty-wall-hooks---3-screw-hole-brass-plated-245-p.asp Re: foccer font of knowledge - mirror hanging - fazersharp - 04-12-16 I would replace the cord with wire. The thing with those hooks with 3 holes is that if your plaster is a bit iffy or thick and you don't get into some brick , the holes being so close can weaken the one next to it. Re: foccer font of knowledge - mirror hanging - red98 - 04-12-16 Iam with sharpie two screws into wall plugs as wide apart as you can get them...as sharpie, make sure your well into brick..if its over the fireplace , a proper one :rolleyes you should'nt have a problem......let us know how you get on
Re: foccer font of knowledge - mirror hanging - tommyardin - 04-12-16 Retired brickie here, I'm with Sharpie and Red also. 2 inch number 8 screws times 2, brown rawlplugs. I personally would put the screws 3 or 4 inches in from either side of the mirror in the place you wish to hang the Mirror, that way the forces will be almost straight down, (Also helps reduce the seesaw/swinging action associated with centre hanging) Make sure that the fixings in the mirror frame itself are good. Using 2 inch screw will ensure that the screws go into the brickwork or blockwork and not just into the plaster. Another thing you can do is put a washer over the screws before screwing them into the wall they help stop the hanging wire lifting off the screws so easily. |
