Brighter headlight bulbs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZ6 / FZ6 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=77) +--- Thread: Brighter headlight bulbs (/showthread.php?tid=77006) |
Brighter headlight bulbs - Cwodavids - 26-11-16 Simple question, any recommendations for brighter headlight bulbs for a 2010 FZ6 Fazer? Re: Brighter headlight bulbs - JC - 27-11-16 100w bulbs Re: Brighter headlight bulbs - Cwodavids - 27-11-16 Okay, perhaps I should have been very specific. Are there any specific make/model of bulbs that people have used and would recommend? Re: Brighter headlight bulbs - Grahamm - 28-11-16 I switched to Osram Nightbreakers a few years back and found them very effective. Re: Brighter headlight bulbs - Cwodavids - 28-11-16 Doing a good deal on amazon on these just now. This has brought up a few other questions. What is the difference brtween H7 and H4 and do I need both? What is the max wattage I can fit? Am I able to make both headlights dipped and both switch on as main beam? Re: Brighter headlight bulbs - davebike - 29-11-16 H7 is the dip on the LHS H4 only uses the main beam on the right Dip beam produces a Dip to right beam fro Drive on right ! Me I gave up with Better bulbs used HID kit in the H7 and just done a H4 HID conversion for main beam (watch out many only up rate the Dip ! Both light need alining after conversion both came down a bit If you don't run heated grips / clothing you can put an off road use 100/160 w in the main beam I did fro a time very good Re: Brighter headlight bulbs - Cwodavids - 29-11-16 "H7 is the dip on the LHS H4 only uses the main beam on the right Dip beam produces a Dip to right beam fro Drive on right !" The H4 part has confused me a little. Are you saying that if in countries that drive on the right that the H4 is wired differently and only uses dip on the right with the left side not functioning on dip? I have just had a thought, is it possible to rewire so that both sides are able to be dipped and main beam? Re: Brighter headlight bulbs - Grahamm - 02-12-16 (29-11-16, 08:38 PM)Cwodavids link Wrote: I have just had a thought, is it possible to rewire so that both sides are able to be dipped and main beam? Look up FZ6 Dual Headlamp Mod. Re: Brighter headlight bulbs - Cwodavids - 02-12-16 I have and it just explains dipped lights not main beam, does anyone have a dual main beam mod link? Re: Brighter headlight bulbs - davebike - 02-12-16 If you power up the Right headlight the H4 bulb on dip and look at the beam pattern it is a Z dip to the right! for drive on the right NOT UK Drive on the left ! Beam dips but kicks up to the right MOT fail and a possiable nick fro dazzling on coming ! Both me light are now 35W HID both needed re alining I do not and will not unless going to a Drive on right contery use the RHS headlight as a dip ! Re: Brighter headlight bulbs - JC - 06-12-16 I wouldnt go for both higher wattage bulbs and dual headlight mod Re: Brighter headlight bulbs - davebike - 06-12-16 The duel Headlight mod on My FZ6 produces produces a NON MOT leagal beam pattern with a kick up on the right as well as the left ! The right hand reflector is fro Drive on right markets only ! MOT fail and possiable ticket fro dazzeling on comeing Dip is hard to upgrade without using HID or very Good LED as H7 is hard to find over 55W Main is easy if you don't use heater grips or clothing just fit a off road 100/160W H4 really great main beam about the same as I get from A 35W HID Re: Brighter headlight bulbs - Kye - 16-12-16 I have just put some Philips Extreme Vision into mine. They've not made much difference. The verge gets most of the light. Does anyone else find this? Or do I need to get the alignment checked? The Main beam doesn't do much (upgraded bulb) but light up stuff on the right hand side of the road above the height of traffic. Can anyone recommend some LED side lights? I've tried a couple of brands now. The left side dies within minutes. As far as I know the LEDs have resistors built in to them. Re: Brighter headlight bulbs - Grahamm - 17-12-16 (16-12-16, 12:09 PM)Kye link Wrote: I have just put some Philips Extreme Vision into mine. They've not made much difference. The verge gets most of the light. Does anyone else find this? Or do I need to get the alignment checked? The Main beam doesn't do much (upgraded bulb) but light up stuff on the right hand side of the road above the height of traffic. Sounds like you do need to check the alignment. I did mine by finding an unlit lane with a *long* straight section (so plenty of time to see other traffic!) then tweaking the adjustment screws until I got the beam-spread I liked. NB Don't take too long over it. When the engine is ticking over, you're not re-charging the battery, so, when you're doing the beam, you're going to be running it down and might end up having a flat battery! Re: Brighter headlight bulbs - davebike - 19-12-16 Yes Grahamm Neither of mine were great with normal bulbs I swaped to HID and both needed lots of adjustment ! Most of the problems with HID kit is not doing the adjustment and I think most other head lamp problems come down to adjustment it is not easy if fact it a Pain but once done light are very good FZ6 reflectors are very good Re: Brighter headlight bulbs - Kye - 06-01-17 The HID idea is bouncing around my brain. I'm waiting for the dipped bulb to blow before I take the jump. I'm a bit worried about how they would fit and the glare. Can anyone suggest a guide to follow so I can adjust my lights? I have no idea how to set them up so that I'm not blinding other road users. Or competing with the stars. Many thanks! Re: Brighter headlight bulbs - davebike - 28-01-17 Tow options After dark find a road with little or no traffic You need a 10m socket up down adjustment and an 8mm socket left right Adjust so the cut of is 10m in front of the bike and the LHS rise goes along the curb / hedge when the bike in in a nornal riding possision you on it and upright Other option go to a good MOT centre or workshop who will have a set up to do it in daytime |
