Gen 2 adjustable dogbone - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gen 2 adjustable dogbone (/showthread.php?tid=76958) |
Gen 2 adjustable dogbone - Rob R - 16-11-16 After fitting an R1 shock I had to lower the ride height (R1 shock is about 1" longer than the FZ1 shock). I checked fleabay and decided I could make an adjustable linkage myself so I bought a right & left handed M12 rod end bearing and a length of 19mm stainless hex and this is the result. Total cost £12.50! Re: Gen 2 adjustable dogbone - devilsyam - 17-11-16 Tip Do a trial fit to set length Undo one end making sure other is fully tight Note position of lock nut Get some larger heat shrink and to to length to cover the nuts refit the end and tighten pull know the heat shrink to do this then making sure nuts are covered shrink down This will ensure all stays together Re: Gen 2 adjustable dogbone - Andy W - 17-11-16 Looks jolly ingenious & cost efficient to boot! Nice one!This Devilsyam fellow has some experience in these matters I believe, so may be worth heeding!
Re: Gen 2 adjustable dogbone - Rob R - 17-11-16 Thanks for the advice Devilsyam. I chose to use a right hand and left hand thread so I could adjust it without having to remove the linkage, I'd not given any thought to protecting the threads... Rob Re: Gen 2 adjustable dogbone - Bubbaad - 19-11-16 Great idea......You got the item number for the hex bar.........Ta Re: Gen 2 adjustable dogbone - devilsyam - 19-11-16 yep rob it will protect the threads but more over its to lock the nuts just in case they work loose Re: Gen 2 adjustable dogbone - Rob R - 20-11-16 (19-11-16, 11:40 AM)Bubbaad link Wrote: Great idea......You got the item number for the hex bar.........TaNo number/grade for the hex bar, just a nice free cutting s/s. |
