Any easy way to remove carburetors? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Any easy way to remove carburetors? (/showthread.php?tid=76921) |
Any easy way to remove carburetors? - Bimbam - 07-11-16 Hey I am helping my brother to remove the carburetors for cleaning and new o-rings. Is there any easy way to remove the carbs? Re: Any easy way to remove carburetors? - Bretty - 08-11-16 Not really. Air box/filter needs to move backwards, which means tank and side covers off and a bit of a pig re/connecting the throttle cables and getting to all the screws on all the clamps. just take your time with it. Re: Any easy way to remove carburetors? - Bimbam - 08-11-16 Thx. No problem. it is winter now Re: Any easy way to remove carburetors? - Dave48 - 08-11-16 And dont forget to plug the inlet tracts with cloth when carbs off to avoid dropping stray parts into motor :eek I speak from experience! Re: Any easy way to remove carburetors? - CaptainCazador - 08-11-16 Top tip when you come to refitting them. A broom does the trick.
Re: Any easy way to remove carburetors? - midden - 08-11-16 (08-11-16, 10:17 AM)CaptainCazador link Wrote: Top tip when you come to refitting them. is that a knife or fork in the airbox? Re: Any easy way to remove carburetors? - Dave48 - 08-11-16 Dont know about the broom technique but when I refitted mine into new carb inlet rubbers I smeared a little red rubber grease around inside of new rubbers, moved the air box fully back and then inserted a thin piece of soft wood behind bank of carbs to apply even leverage to all 4-they popped in and also held them in place while i did up the clamp screws. Remove said piece of wood and move airbox fwd & refit screws & clamp rings. Dont forget to reconnect throttle cables & choke before sliding carb assy in. Dont forget to check small bore hoses for carb heater circuit & condition of fuel hoses- its a pain of a job if you are working on your own but not impossible.Finally balance carbs -job done,sorted! Re: Any easy way to remove carburetors? - CaptainCazador - 08-11-16 (08-11-16, 11:16 AM)midden link Wrote: [quote author=CaptainCazador link=topic=21367.msg245338#msg245338 date=1478596650] is that a knife or fork in the airbox? [/quote] Fork.[size=78%] I enjoyed a chicken and mushroom pot noodle when I was rebuilding my steed. [/size]
Re: Any easy way to remove carburetors? - tommyardin - 12-11-16 (08-11-16, 09:16 AM)Dave48 link Wrote: And dont forget to plug the inlet tracts with cloth when carbs off to avoid dropping stray parts into motor :eek I speak from experience! Same as that, if you service your bike with the tank off and decide to remove brackets or bits from under the tank for easier access to get the plugs back in, a bit of rolled up paper kitchen towel in each spark plug well might save lots of tears :'( Re: Any easy way to remove carburetors? - darrsi - 12-11-16 Crikey, i'm surprised you haven't got 3 Wise Men huddled round your bike in that photo. :lol Re: Any easy way to remove carburetors? - tommyardin - 12-11-16 (12-11-16, 05:43 PM)darrsi link Wrote: Crikey, i'm surprised you haven't got 3 Wise Men huddled round your bike in that photo. :lol Looks to me like hes been playing a game of fucking Quidditch :lol :wall :fish :groan [/size] |
