Fitted new clocks, speed seems to be optimistic. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fitted new clocks, speed seems to be optimistic. (/showthread.php?tid=76754) |
Fitted new clocks, speed seems to be optimistic. - Emerald Rider - 08-10-16 Hi All, Fitted second hand to my FZ1. I don't know if they came off an FZ1, but every thing works, except the speed is reading over. From my gut feeling I would say 30% over. Any one got any ideas? or know if it can be easily adjusted? Thanks. Re: Fitted new clocks, speed seems to be optimistic. - slappy - 08-10-16 Not being funny but are you sure you have selected mph and not kph on the speedo? Re: Fitted new clocks, speed seems to be optimistic. - Emerald Rider - 09-10-16 Yes I did check! Re: Fitted new clocks, speed seems to be optimistic. - pilninggas - 09-10-16 that's weird, you'd think it would be the same. if it were just erractic, then it'd be the usual check the connector terminals. Perhaps youll have to fit a speedohealer and calibrate the numbers down? Re: Fitted new clocks, speed seems to be optimistic. - tex - 09-10-16 could be a different size sprocket . were the originals modded in any way. Re: Fitted new clocks, speed seems to be optimistic. - Emerald Rider - 14-10-16 Thanks for the replies lads, I'm pretty sure every thing is standard on the bike. The seller told me the clocks came off a 2010 bike. I'm going to 'calibrate' them with a satnav to confirm my suspicions! Re: Fitted new clocks, speed seems to be optimistic. - Rob R - 14-10-16 (08-10-16, 10:12 PM)slappy link Wrote: Not being funny but are you sure you have selected mph and not kph on the speedo?I remember how shocked I was after fitting an Optimate lead, switching on the ignition and discovering my odometer reading showing a massive increase..... Rob Re: Fitted new clocks, speed seems to be optimistic. - Emerald Rider - 15-10-16 Tested the clocks today against a speedo app on the phone. When I'm doing 50kph the clocks are reading 90kph, at least now I know I'm not losing my marbles :b Anybody know if there are any subtle differences between the earlier of later models or the N and S which could result in this? Re: Fitted new clocks, speed seems to be optimistic. - ram - 15-10-16 (15-10-16, 07:59 PM)Emerald Rider link Wrote: Tested the clocks today against a speedo app on the phone. When I'm doing 50kph the clocks are reading 90kph, at least now I know I'm not losing my marbles :b Anybody know if there are any subtle differences between the earlier of later models or the N and S which could result in this?so your speedo is in kph? def sounds like its reading in mph maybe has been refaced like here? http://foc-u.co.uk/index.php/topic,1974.0.html Re: Fitted new clocks, speed seems to be optimistic. - Emerald Rider - 15-10-16 (15-10-16, 10:49 PM)ram link Wrote: [quote author=Emerald Rider link=topic=21195.msg243835#msg243835 date=1476557984]so your speedo is in kph? def sounds like its reading in mph maybe has been refaced like here? http://foc-u.co.uk/index.php/topic,1974.0.html [/quote] No, I have a digital speedo, it's set to KPH, when on MPH it's out by the same amount as aswell..... |
