HELP! META M357T-V2 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: HELP! META M357T-V2 (/showthread.php?tid=76730) |
HELP! META M357T-V2 - gixersix - 03-10-16 Hi, all you FOC-cers I've had what I thought was the well-documented problem, with my META M357T-V2 (NOT V2-1) internal battery dying. I've seen all the previous posts plus similar ones from other forums. Wanting to remove the immobiliser temporarily, I've tried to pin-out the plug(s) with paper clips. as per photo found elsewhere on here (attached for reference). The starter motor is now turning over, but the bike is making no attempt to fire. Seems like the ECU pin-out isn't working.[size=78%] I've seen on other forums (and our own FZ6) that there are different pin-outs for different bikes - is it possible I've got the wrong 2 connections for mine? 2004 FZS1000 (Mk1) by the way. Sorry for the urgency but the bike is my only form of transport here at the moment - my other bikes have now been put up for winter and are in fact parked 170 miles away. Oh and I'm booked on a Welsh riding weekend THIS weekend. DOH![/size] PS - also, I've found a magnet (for a reed switch) which was glued to my seat, and the matching switch fastened inside the frame. What does this do? I assumed it put the alarm in "service" mode. Coincidentally, the magnet had fallen off the seat but for the time being, I have taped it to the reed switch, so it thinks the seat is in place. Thanks, in anticipation. Dave Re: HELP! META M357T-V2 - ram - 03-10-16 dont know where you are but this bloke came and removed mine (same alarm) if your stuck. https://bikealarmman.com/ Re: HELP! META M357T-V2 - Freck - 04-10-16 The reed switch on the seat is just for when the alarm is armed, so if the seat is lifted it'll trigger the siren, not for a service mode.
Re: HELP! META M357T-V2 - Fazerjon - 04-10-16 I had a similar problem with mine, I ended up buying a complete new 'plug & play' meta 357T-V2with new fobs, delivered for about £160, took about 10 minutes to fit. Re: HELP! META M357T-V2 - unfazed - 04-10-16 It is not working because the pin outs looping shown are incorrect, pm me your email address and I will send you a picture of the correct ones Re: HELP! META M357T-V2 - gixersix - 06-10-16 Thanks for all the help and guys. Due to the impending Welsh trip, on Tuesday morning, I contacted Abacus Alarms who flogged me one of their Bypass Plugs. Removed my paper-clip, plugged this in - it runs (thank fuck). They also offered me a replacement META357 for £120 but with the expense of the trip this weekend, that was a non-starter at the moment. The 357 is available on eBay for £99 anyway, and can be plugged in later. Thanks again - REALLY :thumbup Re: HELP! META M357T-V2 - unfazed - 06-10-16 Take a god lock with you :lol Enjoy the trip |
