disconnecting main keyswitch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: disconnecting main keyswitch (/showthread.php?tid=76710) |
disconnecting main keyswitch - ptolemyx - 01-10-16 I want to completely remove the top yoke to respray it. How do I disconnect the wiring to the main key switch? Or will I have to drill out the (very hard) security bolts to remove the whole switch assembly from the top yoke???? I've downloaded the workshop manual and can't find an answer there. Re: disconnecting main keyswitch - NorthWestern - 01-10-16 I drilled mine out, wasn't that bad really Intentionally left blank Re: disconnecting main keyswitch - NorthWestern - 01-10-16 That is to say I was removing the barrel from the yokes. There is a connector block you can unplug if just removing the yokes Intentionally left blank Re: disconnecting main keyswitch - ptolemyx - 02-10-16 Disconnected at the connector under the tank. Now to drill and eazyout the bolts - simples really :rolleyes |
