HELP!! FZ1 S Rearsets and Ground Clearance - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: HELP!! FZ1 S Rearsets and Ground Clearance (/showthread.php?tid=76644) |
HELP!! FZ1 S Rearsets and Ground Clearance - Tribal Chestnut - 21-09-16 I need more peg/ground clearance on my FZ1-S so am contemplating fitting rearsets, however will these solve my problem or will I just end up touching the centre stand or something else down? Re: HELP!! FZ1 S Rearsets and Ground Clearance - Tribal Chestnut - 22-09-16 As a quick fix, will the pegs still touch down first if I remove the feelers/guides that poke out beneath them? Re: HELP!! FZ1 S Rearsets and Ground Clearance - Dudeofrude - 22-09-16 You could possibly remove the centrestand (providing you have a sidestand) and fit adjustable rearsets to their highest setting but it'd probably make the bike incredibly uncomfortable and just for the sake of an inch or 2 clearance. If it's just for cornering then have you not tried just hanging off the bike a bit more? Re: HELP!! FZ1 S Rearsets and Ground Clearance - Tribal Chestnut - 22-09-16 Sadly need to keep the centre stand as I commute all year and it makes maintenance so much easier. I could probably hang off it a bit more with practice, but spent much of yesterday hanging off but still caught the pegs. It's a tad frustrating as I'll find myself out braking someone, but then we're into the corner and they're gone. Giving myself a little more clearance would just help me carry a bit more speed whilst I work on my lines and body position. Re: HELP!! FZ1 S Rearsets and Ground Clearance - Dudeofrude - 22-09-16 Have you not thought of picking up a cheap track bike then? You can get an old zx9/thunderace/gixxer for less than a grand. Doesn't need mot/insurance/tax if you can get it trailered or in the back of a van to the track Probably cheaper than a decent set of rearsets haha and you don't have to worry about binning it so much? Re: HELP!! FZ1 S Rearsets and Ground Clearance - Tribal Chestnut - 22-09-16 Have a 5PW R1, but need to sort out some sort of fueling issue, so want to have a bit of fun with the FZ1 in the meantime. Will probably just take off the feeler thingies for now and see what touches down first. Could be interesting. Re: HELP!! FZ1 S Rearsets and Ground Clearance - Dudeofrude - 22-09-16 Well as long as it's not ya face then I'm sure you'll be fine ?? haha Re: HELP!! FZ1 S Rearsets and Ground Clearance - Dustydes - 22-09-16 Shorter dog bones ?? Better rear shock, if not fitted. R6? Have you checked suspension set up, rear sag Re: HELP!! FZ1 S Rearsets and Ground Clearance - Tribal Chestnut - 22-09-16 Thanks guys. I'll be back on track 3/10, so wouldn't have time (let alone the aptitude) to mod the suspension before then, possible longer term consideration though. If I bin it I'll post pics here first! Re: HELP!! FZ1 S Rearsets and Ground Clearance - Dustydes - 22-09-16 Get an R6 shock and some shorter dog's Drill top bush in shock Fit with 2 washers, job done http://thewolftamer71.blogspot.co.uk/2011/08/fz1-mod-rear-suspension-upgrade.html Or buy one from devilsyam on here, set up and with dog bones He has one for sale at moment http://foc-u.co.uk/index.php/topic,151.650.html Easy to fit takes 30min's Best mod for cornering you can get for £150ish I would say a must if you want to do track days and keep up with others in the corners Will transform your bike, lots of info on r6 mod if you google Re: HELP!! FZ1 S Rearsets and Ground Clearance - tex - 22-09-16 (22-09-16, 07:27 PM)Dustydes link Wrote: Get an R6 shock and some shorter dog's the r6 shock is for the gen 1 , i think you can mod a r1 shock for the gen 2 Re: HELP!! FZ1 S Rearsets and Ground Clearance - Rob R - 22-09-16 For a Gen2 FZ1 you'll need a Satans adapter and an R1 shock (2004-2008). This will give you about 20mm extra ride height (R1 shock is longer than the FZ1) and a much better shock. It will also mean that you back wheel will stay on the tarmac when you hoist it onto the centre stand. Rob Re: HELP!! FZ1 S Rearsets and Ground Clearance - Tribal Chestnut - 23-09-16 Thanks again chaps. Once I've sorted the pegs I'll probably just concentrate on my skills rather than fettling the suspension - if I swap the shock and find the centre stand subsequently isn't so effective then I might as well remove it, which is a compromise too far for this bike. When I'm at a point that a better shock will be making a noticeable difference to my riding then I might as welove just be using the other bike. |
