Carb o-ring size - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Carb o-ring size (/showthread.php?tid=76610) |
Carb o-ring size - shlomimor - 16-09-16 Hello Does anyone check if this o-rings are correct dimensions? All dimensions are in millimeters. The diameter listed is cross section of the o-ring cord. This is often times referred to as the width of an o-ring. Main Jet: 5.5 ID x 8.5 OD x 1.5 DIA McMaster-Carr# 9262K519 Float Needle Fuel Valve: 7.5 ID x 10.5 OD x 1.5 DIA McMaster-Carr# 9262K629 Idle Air Screw: 3.0 ID x 5.0 OD x 1.0 DIA McMaster-Carr# 9262K441 Under diaphragm cap: 2.5 ID x 5.5 OD x 1.5 DIA McMaster-Carr# 9262K626 |
