2005 Gen 1 Switched Live Question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: 2005 Gen 1 Switched Live Question (/showthread.php?tid=76588) |
2005 Gen 1 Switched Live Question - robbo - 13-09-16 Hi fonts of all knowledge, Just bought a discounted Garmin Zumo from Aldi. Where would be the best and easiest point to hook up to a switched live. Had been under the misapprehension that one side of the horn was the place, but that's not so. Thanks in advance wise ones. Re: 2005 Gen 1 Switched Live Question - sadlonelygit - 13-09-16 Sidelight feed Re: 2005 Gen 1 Switched Live Question - BBROWN1664 - 13-09-16 Rear brake light switch Re: 2005 Gen 1 Switched Live Question - VNA - 13-09-16 Check out the guide to fitting heated grips on the old forum. You should find it here - http://fazerowners.yuku.com/topic/5650/HOWTO-Fit-your-heated-grips-PICS-BACK#.V9gxo62oroQ Skroll down the first page to the photos I added. You'll see there are spare tags on the live feeds to the fuse box. Solder on your wire with an inline fuse. Re: 2005 Gen 1 Switched Live Question - robbo - 13-09-16 Excellent guys,you've come up trumps again.Thank you all. Re: 2005 Gen 1 Switched Live Question - robbo - 14-09-16 All done. Decided to do the fuse box option. Prising the clips whilst pushing the crimps out was a bit awkward on your own, but other than that very straightforward. Now I'm a fully fledged sat nav wanker. Thanks again guys, what a great forum. |
