Carb balancing/Good samaritan - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb balancing/Good samaritan (/showthread.php?tid=76580) |
Carb balancing/Good samaritan - chris.turton - 12-09-16 Hi there, Is there anyone about in the Wakefield/Leeds area that might be able to help out with balancing my carbs? I don't have the tools to do it myself (or any idea how to for that matter) and I don't have the budget for the garage right now but from all I've read here it could may well be the solution to my general lumpiness. Thought it had to be worth a try, if I didn't ask I'd never know. (There's a cat in a box somewhere thinks I'm a fool) Cheers. Chris Re: Carb balancing/Good samaritan - darrsi - 12-09-16 Make sure you have a clean or unclogged air filter before doing it, it can make a difference in the results if the bike's not breathing properly. :thumbup Re: Carb balancing/Good samaritan - chris.turton - 12-09-16 I've just changed air filter, plugs and TPS unfortunately to no avail. It sorts it out for a while but then back problems. Re: Carb balancing/Good samaritan - darrsi - 12-09-16 Balancing will help without a doubt, so you've done all the right things and are half way there. Re: Carb balancing/Good samaritan - chris.turton - 12-09-16 Well there's some good advice on this forum, it's bloody brilliant. |
