Starting problems on 2008 avensis - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Starting problems on 2008 avensis (/showthread.php?tid=76578) |
Starting problems on 2008 avensis - tex - 12-09-16 After a bit of advice , Toyota avenue 08 d4d diesel . Drives fine no warning lights coming on cranking OK but won't start happend a week ago so bumped started it and was OK until today, sometimes it takes a bit to start but no go this morning. Before I take it to the garage anyone got any ideas. Thanks Re: Starting problems on 2008 avensis - BBROWN1664 - 12-09-16 Try some ezstart in the air filter. Could be a battery problem causing the ECU to not pump fuel whist cranking due to voltage drop. Re: Starting problems on 2008 avensis - Frosties - 12-09-16 Starter motor on the way out leaving not enough current for the glow plugs. Ignition barrel issue. Any exhaust emissions when trying to start? Immobiliser issue? Re: Starting problems on 2008 avensis - crickleymal - 13-09-16 Glow plugs. Battery. Could be immobiliser although because it cranks over I'm not sure. Do you have a spare key? If so try that and that will eliminate the immobiliser. Re: Starting problems on 2008 avensis - tex - 13-09-16 Thanks for all your help , I'll try all suggestions I got it towed to a hill near by tried to bump start it, no joy, there no smell of diesel so maybe fuel pump . |
