Speedohealer v4 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Speedohealer v4 (/showthread.php?tid=76571) |
Speedohealer v4 - Dudeofrude - 11-09-16 Just found one under my seat? Never heard of it before. I've done a quick Google and found the website but juts keep saying about correcting the speedo? I don't know why it wouldn't be right anyway? Does it mean I might not have stock gearing? Are they any good? Or shall I get rid of it? Re: Speedohealer v4 - Tmation - 11-09-16 It might have been fitted because the gearing has been changed or the previous owner was anal about correcting Speedo error. Re: Speedohealer v4 - Dudeofrude - 11-09-16 That alright if it's set properly. Now I'm gonna need to find a way to test it haha Re: Speedohealer v4 - BBROWN1664 - 12-09-16 Or because the bike is an import and shows everything as kmh so this was fitted to make it mph values. Most likely because the previous owner changed the sprockets to non-standard sizes at some point and the FZS1000/FZ1 has the speedo driven off the gearbox. Re: Speedohealer v4 - Dudeofrude - 12-09-16 Yeah it definitely not an import. Besides you can switch from mph to kph on the speedo it's self by holding down one of the buttons? I'm thinking it must be a sprocket thing. I'm having my mechy give it a once over next week anyway so I'm sure he'll let me know Re: Speedohealer v4 - Dudeofrude - 18-09-16 When I turn it on the display say -16.7 I don't suppose any of you clever people could tell me what that means for my gearing? Whether it's high or lower than normal? Re: Speedohealer v4 - Dudeofrude - 18-09-16 Just been playing with the app and the closest match I can get is 16.4 and that's from a 15 45 sprocket set up. Seems a little drastic to drop 2 front teeth doesn't it? Re: Speedohealer v4 - CatalinU - 24-03-20 Qucik question. As having the standard factory size pinions, does the speedo shows corectly? I mean does it shows like a GPS wich is the real speed? I was thinking if not, then i should get a speedo healer to correct that? Or the speedo corrects only the ratio betwen sprockets? Re: Speedohealer v4 - kebab19 - 24-03-20 No the speedo is off by around five percent. Adding a 17 tooth front sprocket makes it almost 100% accurate: course, that reduces the acceleration (boo!) but improves economy slightly (yay!) I have the device on mine as lowering the gearing makes it read even more inaccurate. I currently have a 45t rear sprocket fitted and from memory adjusted the healer to 7.3 Re: Speedohealer v4 - Timbo - 27-03-20 (11-09-16, 12:57 PM)Dudeofrude link Wrote: Just found one under my seat? Never heard of it before. I've done a quick Google and found the website but juts keep saying about correcting the speedo? I don't know why it wouldn't be right anyway? Does it mean I might not have stock gearing? I am on my second Fazer 1000, both had\have a 15t front and a Speedhealer to correct the speedo. The improved acceleration from the 15t is fab and you will not miss the top end anyway. Anything over the ton and you are in deep doo doo! And you will still get 50mpg on average (both of mine were\is Ivanised) With the front sprocket cover of count the the teeth, my old bike is out there somewhere .... last seen on the Pile o' Shite (IOW). I should never have sold it!!! Bw Timbo Re: Speedohealer v4 - CatalinU - 28-03-20 So as for future, when the time will com to change my sprockets and chain, is it worth going higher on the front sprocket? Not looking into wheelies, but more into fuel economy. What would be the best option to go for to get that extra fuel? Re: Speedohealer v4 - robbo - 28-03-20 Yep. Up one on the front would give better economy. You'd lose some engine braking at town speeds and might need to slip the clutch a tad to get off the lights. But you'd achieve what you're after. Re: Speedohealer v4 - CatalinU - 28-03-20 Does anyone know whats the part number for a FZS1000 gen1? |
