RHS Switching Gear Locating tab... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: RHS Switching Gear Locating tab... (/showthread.php?tid=76566) |
RHS Switching Gear Locating tab... - anutz - 10-09-16 Anyone had success at fixing the "locating" tab on the Right Handlebar Switch cluster, that also has the throttle cables Just removed mine to remove the throttle cables to get carbs out and its cracked and fell off, can only see units with no light switches on ebay, i may have to transfer things around if i buy one, but strange i can see not many with the right configuration.. Re: RHS Switching Gear Locating tab... - ram - 10-09-16 i had this on another bike (triumph) i drilled a small hole where the tab was and screwed in a small self tapper but left the head stuck out so it went into the handlebar hole. or you could wind some tape onto the bar so it grips tighter Re: RHS Switching Gear Locating tab... - unfazed - 10-09-16 Last time I had that issue, I drilled a small hole carefully in its place in the switch gear (5 to 6mm deep), glued a cut down steel nail which fitted the hole in the bars (10 to 12mm long) into the hole. Sorted :thumbup Re: RHS Switching Gear Locating tab... - BBROWN1664 - 12-09-16 :agree I have in the past just packed the bars with tape to make the switch gear clamp down harder. |
