Front brake light switch - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front brake light switch (/showthread.php?tid=76535) |
Front brake light switch - wickedmonkey - 07-09-16 Hi guys, After replacing my front brake pads, my front brake switch doesn't quite come on soon enough. Is there any way of adjusting this? Does changing the brake lever span dial setting effect when the switch is activated? Many thanks, David. Re: Front brake light switch - BBROWN1664 - 07-09-16 No and no. The switch is not adjustable and comes on when the lever moves a predefined amount. The Span setting is just adjusting how far you reach for the lever, not how far the lever moves. Re: Front brake light switch - Fazerider - 07-09-16 You may be able to reposition the switch slightly by taking it off, cleaning the area then tightening the screws while pulling the switch back. Re: Front brake light switch - wickedmonkey - 08-09-16 Thanks. I might have to try that |
