indicator diagnostics? (edit: and headlight) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: indicator diagnostics? (edit: and headlight) (/showthread.php?tid=76474) |
indicator diagnostics? (edit: and headlight) - Bretty - 29-08-16 There's always something going wrong with my bike. ![]() I went for a ride this morning and noticed the left hand indicator dashboard light blinking quicker than normal. It usually means there is a bulb out, so I look and neither bulb (front or rear) is working?! Can someone suggest the issue or point me at some diagnostics? Mechanics I can do all day long, electrics I'm lost. Do the left and right indicators have separate fuses? Or have I got a wiring or connection fault? Edit:... and I just realised that the headlights are not working either. Full beam yes, dipped beam and 'sidelights' - dead. :-( Thanks! Brett Re: indicator diagnostic? - Jules-C - 29-08-16 They share the same fuse so it's looking like a wiring or connector fault. Since the other side is working ok the wiring to relay and up to the switch is ok so it's either switch itself or connector box under tank or the wires between them |
