FZ1 Rear Shock - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZ1 Rear Shock (/showthread.php?tid=76402) |
FZ1 Rear Shock - Harvey - 19-08-16 I am approaching 30k miles do you think l should replace the original rear shock? If so what would be a good but reasonably priced replacement? Thanks in advance. Re: FZ1 Rear Shock - stevegixer - 19-08-16 I have a very low milage (4.5k) rear shock cheap . But you could contact luke ( devilsyam) for an R6 converted shock.a proven upgrade at a reasonable price. Re: FZ1 Rear Shock - Gary - 19-08-16 Is the R6 shock suitable for a Gen 1 or 2? Re: FZ1 Rear Shock - JKay - 19-08-16 Gen 1 only Re: FZ1 Rear Shock - Rob R - 19-08-16 I bought a Satan's adapter and fitted an R1 shock. Total cost was about £150. The difference is night and day. Rob Re: FZ1 Rear Shock - Ballmead - 19-08-16 Nitron make an excellent shock for the Gen II FZ1, the NTR R1 sport. It works well and is easy to set up and is perfect for road use with the occasional trackday. http://www.nitron.co.uk/catalogue_item.php?catID=12778&prodID=74515 Re: FZ1 Rear Shock - Dustydes - 20-08-16 R6 shock fantastic for the money. Get the best you can afford, google fzs r6 shock. Make sure it looks like shock in link drill out top bush from 10mm to 12mm 2 spacers to make up the narrower R6 shock (top) 2.5mm each 130mm dog bones to bring back up to stock 20 mins to fit http://thewolftamer71.blogspot.co.uk/2011/08/fz1-mod-rear-suspension-upgrade.html Re: FZ1 Rear Shock - Harvey - 23-08-16 So far l as can see these mods are for Gen 1 but mine is a Gen 2? Re: FZ1 Rear Shock - Rob R - 23-08-16 No, Satan adapter enables you to fit R1 shock 2004-2007 to Gen2 without relocating Reg/Rec or exup motor. |
