LED indicators - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: LED indicators (/showthread.php?tid=76395) |
LED indicators - Ricky - 18-08-16 I am hoping to fit a set of LED indicators to my Gen 1. I know I need to fit a different relay or resistors, but which is the best way to go? Is the relay easy to get, and where is it on the bike? Re: LED indicators - Fuzzygoth - 21-08-16 I am actually in the same boat, my rear indicators are corroded to all hell so I thought I'd replace them with LED's but I am pretty sure I'll need and LED flasher adaptor too to prevent hyper blinking on the indicators :/ If anyone has links to a good guide on how to do this it would be appreciated. Fuzzy Re: LED indicators - Gabrael72 - 21-08-16 If you change the indicators to LED's you need to lift the seat and check if you have a two prong or three prong relay, then just buy the one that's appropriate, real easy fix, no soldering involved, just plug and play! Sent from my iPhone using Tapatalk Re: LED indicators - Fuzzygoth - 22-08-16 Excellent, so the relay is just under the seat then? that should make it fairly easy
