C-spanner for headset - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: C-spanner for headset (/showthread.php?tid=76383) |
C-spanner for headset - Bretty - 17-08-16 Hi all, What size C-spanner do you need to adjust the head bearings? Can you use the one in the tool kit for the rear suspension adjustment? Or will I need to order one? And if so what size do I order? Thank you! Brett Re: C-spanner for headset - Jules-C - 17-08-16 I'm not sure of the size but it's a lot smaller than the shock absorber c-spanner Re: C-spanner for headset - joebloggs - 17-08-16 (17-08-16, 12:35 PM)Bretty link Wrote: Hi all,Tap it round with a flat bladed screw driver, set the bearing and lock it up. Re: C-spanner for headset - Punkstig - 19-08-16 What Joe said, I'll add don't tighten it more than a quarter turn to start with! Re: C-spanner for headset - His Dudeness - 19-08-16 I bought one off ebay a good while back that you could attach a torque wrench too with an adaptor. The link that I have to the one I bought doesn't work anymore but I think it was a 43mm one. I'm not 100% sure on that. You can measure your headstock bearing to confirm it. Here's a link to a similar one http://www.ebay.co.uk/itm/43mm-STEERING-STEM-HEAD-STOCK-C-SPANNER-WRENCH-43-/152186361142?hash=item236f039536:g:X9UAAOSw3mpXJPur Re: C-spanner for headset - me_groovy - 29-08-16 I use the screwdriver tapping method too, have done on all my bikes. Re: C-spanner for headset - midden - 30-08-16 Have you got a old bicycle spanner they have a c spanner Re: C-spanner for headset - Bretty - 30-08-16 It's all sorted now thank you! It's a ridiculously low torque on these splined nuts. Literally finger tight, then a couple of taps either way to adjust. Locking nut is not much more. I just worked through the Haynes manual and didn't need a c spanner. Cheers! |
