gear linkage bolt - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: gear linkage bolt (/showthread.php?tid=76346) |
gear linkage bolt - HarryHornby - 12-08-16 Hi guys, I've just realised I'm missing the bolt that holds the gear linkage (is that the right name) in place. Do anyone know what size it is? Can I buy one on it's own or do I need to buy the whole bit? Cheers Re: gear linkage bolt - Jules-C - 12-08-16 It's 6mm diameter and standard thread so not a special part any M6 bolt the right length should do. Measure it to check but my guess is 20mm long Re: gear linkage bolt - HarryHornby - 12-08-16 Brilliant, thank you. Off to B & Q I go. :thumbup Re: gear linkage bolt - limax2 - 12-08-16 Correct. Just a bog standard hexagon headed 6mm bolt X 20mm long. You could use a socket head bolt instead if that's what comes to hand. |
