Ignition key barrel maintenance? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Ignition key barrel maintenance? (/showthread.php?tid=76264) |
Ignition key barrel maintenance? - dickturpin - 01-08-16 So....clever folk of the forum.....is it a good maintenance policy to spray WD40, or contact cleaner, or nothing at all down the key barrel once in a while? Re: Ignition key barrel maintenance? - slappy - 01-08-16 I use wd40 to flush ignition and door locks etc out then graphite powder lube to keep them lubed
Re: Ignition key barrel maintenance? - dickturpin - 01-08-16 With no detrimental effects on the electrical contacts? Re: Ignition key barrel maintenance? - slappy - 01-08-16 No detrimental effects that I have noticed, do it about once a year when I service bike or car. Re: Ignition key barrel maintenance? - Frosties - 01-08-16 (01-08-16, 05:48 PM)slappy link Wrote: I use wd40 to flush ignition and door locks etc out then graphite powder lube to keep them lubed I don't use the WD but regularly use the graphite lube (linky below) on bike, car, doors etc when they start to catch a bit - lasts a 'kin long time. https://www.arco.co.uk/product?productcode=3450025&OID=614336 Re: Ignition key barrel maintenance? - darrsi - 01-08-16 I did a bit of research on this and found that graphite lube is great stuff on dry locks, but not so much in wet conditions when it turns into a mush. Re: Ignition key barrel maintenance? - nickodemon - 01-08-16 This stuff is great for any ignition locks and stiff padlocks etc.. http://www.ebay.co.uk/itm/291803898148?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Re: Ignition key barrel maintenance? - darrsi - 01-08-16 (01-08-16, 10:07 PM)nickodemon link Wrote: This stuff is great for any ignition locks and stiff padlocks etc.. That's more like it. :thumbup Whatever you use will always be better than nothing though. A 400ml can of this stuff should also last you approximately 40 odd years as well, so in the future will be money well spent. :lol Re: Ignition key barrel maintenance? - unfazed - 02-08-16 I use wd 40 first and then plain waterproof grease, never an issue with the any locks/Ignition switches Re: Ignition key barrel maintenance? - dickturpin - 02-08-16 Well I have now given all locks a blast of wd40 followed by a quick spray of PTFE lube. Thanks gents... D Re: Ignition key barrel maintenance? - Val - 03-08-16 (01-08-16, 09:01 PM)darrsi link Wrote: I did a bit of research on this and found that graphite lube is great stuff on dry locks, but not so much in wet conditions when it turns into a mush. I use to use it. Now I never use anything that may cause me problems with electrical contacts. I have got some issues with my bike not starting two months ago. I flushed the ignition lock with a lot of electrical contacts cleaner. Problem solved. Now I prefer my ignition lock not lubed, on the bright side the bike starts each time fine. Re: Ignition key barrel maintenance? - Mick-H - 06-08-16 I use Wurth chain lube on mine, no problems so far. Re: Ignition key barrel maintenance? - Slaninar - 06-08-16 Dry locks (not out in the elements) - graphite. Outside - WD40, then a bit of teflon spray. |
