left hand engine seals. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: left hand engine seals. (/showthread.php?tid=76231) |
left hand engine seals. - Bretty - 26-07-16 I changed my gearbox over, over Christmas. I replaced all of the gaskets at the time but reused all the seals on the left-hand side of the engine (clutch rod, gear shift shaft and gearbox output shaft seals). They all looked to be in good condition at the time, so I put gasket seal on the outside of them and stuck them in. I now have a slow leak / drip coming from that side now, which I think is likely to be the output shaft seal. I've bought a whole set of seals and plan to replace them. I'm now trying to get my head around... How easy is that to do without splitting the engine? I'm hoping I can just pull the shafts out then hook the seals out? Output shaft might be a bit trickier to get out? Will I need to drain the oil? Hmm Re: left hand engine seals. - His Dudeness - 26-07-16 As long as the seal doesn't have a lip on the inner edge you should be able to press it in from the outside without taking the engine apart. |
