CARBURETTOR Problems In Low RPMs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: CARBURETTOR Problems In Low RPMs (/showthread.php?tid=76202) |
CARBURETTOR Problems In Low RPMs - 7uckyDog - 21-07-16 Hello everyone! I'm going bananas over a carb problem in my 2002 FZS600. The engine idled perfectly but had power retardation in the top gear when overtaking. The carbs have been taken apart twice now, the first time to be cleaned out because there was rust in the tank. All the jets and passages cleaned and blown out. The bike didn't run the same afterwards so they were taken apart again, o-rings and needle valves replaced, floats tested for leaks, fuel level set, carbs balanced by a shop but still the bike doesn't run properly! It sounds like it doesn't run on all 4 when idling and in low RPMs, but mid range and top is great. It passed MOT today and since I was at the shop they checked the temperature on each cylinder, 3 & 4 are running much cooler than the rest. What more can I check/replace to make my baby run smoothly again??? Re: CARBURETTOR Problems In Low RPMs - topgun44 - 21-07-16 wait for it dark then spray some water over the ht leads and cap and see if you can see very small sparks if you do then you need to change them hopefully it will be the caps if not new or second hand set off coils Re: CARBURETTOR Problems In Low RPMs - Bretty - 21-07-16 As above, new spark plugs and/or caps will likely sort that. Cylinders 3 & 4 are usually exposed to the elements if your bike spends anytime outside on the side stand. Spark plugs corrode, and a build up of dirt, water and corrosion around them doesn't help. Re: CARBURETTOR Problems In Low RPMs - Dave48 - 22-07-16 As suggested I would check HT leads,especially making sure that connectors are pressed fully home onto plug tops. i mention this because I ,like yourself ,recently had my carbs off for overhaul & to fit new intake rubbers. When all back together bike would "bog down"if given a handful of throttle but would eventually "catch up" as the revs built up but wouldnt pull like it should. I ASSUMED carb fault but trying to use a bit of logic decided to remove plug caps,spray inside with a bit of ACF50 and discovered n02 cap wasnt pressed fully home. Result-everything now running right! :lol [size=78%] Its expecting a lot of a 4 pot motor to run 1-MISS-4-3.[/size] :eek [/size][size=78%] [/size] Re: CARBURETTOR Problems In Low RPMs - darrsi - 22-07-16 There's loads of things that could cause this effect unfortunately. It's just a process of elimination one at a time. Bit confusing the way you described that the bike is running oppositely now to when you first had issues before carb cleaning though. Firstly you've not mentioned the air filter at all, when was it last changed and what type/brand do you have? If the bike can't breathe properly then it will affect the idle and lower revs, but can also hold you back at higher revs if it's particularly dirty. Have you even looked into the airbox, it could be clogged up with emulsified oil as well, which my bike has had before. As mentioned are the HT leads and caps okay? You can trim the ends off the HT leads by 5-10mm, and maybe try new plug caps. Don't bother with new OEM ones as the price will make you fall over, but a lot of us have replaced them with NGK ones which work fine and are a great price. http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=SD05F+&_sacat=0 A carb balance by the way will only work well when everything else is running properly. So if your air filter is clogged (or you have an air leak), your TPS is breaking down or knackered, or your spark plug caps are on their way out then a carb balance will be irrelevant and can even make things worse. Even the TPS positioned wrongly can make the bike feel a tad jerky at lower revs, i would do a check on that too, i'm on my 4th one now although this time i bought a brand new one at a much lower price than over here from Germany as it was all getting a bit silly buying used ones that were at least 13 years old and likely to peg out at any time. http://www.ebay.co.uk/itm/Drosselklappensensor-TPS-101-Yamaha-FZS-600-DROSSELKLAPPE-13550-13D60-4HD-85885-/361403667980?hash=item542556560c:g:svIAAOSw2s1UxgsX Another small possibility is moisture in the tank, which will sit lower down in the carbs and cause roughness at idle and low revs but once sloshing away at higher speed won't be as noticeable. Re: CARBURETTOR Problems In Low RPMs - 7uckyDog - 22-07-16 (21-07-16, 10:07 PM)topgun44 link Wrote: wait for it dark then spray some water over the ht leads and cap and see if you can see very small sparks if you do then you need to change them hopefully it will be the caps if not new or second hand set off coils Thanks for the tip, I will check this tonight. (21-07-16, 11:35 PM)Bretty link Wrote: As above, new spark plugs and/or caps will likely sort that. Cylinders 3 & 4 are usually exposed to the elements if your bike spends anytime outside on the side stand. Spark plugs corrode, and a build up of dirt, water and corrosion around them doesn't help. The bike has been kept inside for the last year, the year before it was outside but on the centre stand and usually with a rain cover. But it probably had it's share of exposure to the elements since the #3 spark plug was stuck in the cylinder head. Several months of soaking it in WD40 and working it back and forth did the trick. When the carbs were put back in for the second time new plugs were fitted. I'm definitely going to check the caps and the leads! (22-07-16, 06:54 AM)darrsi link Wrote: Firstly you've not mentioned the air filter at all, when was it last changed and what type/brand do you have? I did check the air filter, it was a bit dirty, not too much though and I managed to shake and brush away most of the dirt out, I put it back in because I didn't have a new one at the time. The box is clean but the small breather filter had some gunk in it which I cleaned out. Rubber inlets are intact. I'm gonna get a new air filter just in case, should I get the OEM one like the one I have or should I go the K&N route? Or is the high flow of the K&N going to screw everything up more? Thanks so much for the link to the plug caps, they are at a great price! I did notice though that they don't have the 45 degree (more or less) elbow but I guess you didn't have issues with that since it has been done many times. I checked the position of the TPS with the speedometer, it showed a tad over 5000 RPM so I twisted it back on forth and made it land on 5000 but theres a lot of leeway on both sides before the RPM needle drops up or down. How can you tell if the sensor is failing? You mentioned that you're on the 4th now, did you measure the resistance in the faulty one when replacing it with a new one? Last but maybe fundamentally not least, the last fuel level measurement showed that carb #3 & #4 have about 1mm higher fuel level, could this tiny difference cause all this uneven running? Like I mentioned initially, cylinder #3 & #4 are running cooler that the rest, what's the logic here, is it because they don't get enough fuel or is it because they are getting too much fuel? Gonna check the spark plugs for colour later to get some indication. Thanks for all the replies! Re: CARBURETTOR Problems In Low RPMs - darrsi - 22-07-16 (22-07-16, 02:56 PM)7uckyDog link Wrote: [quote author=topgun44 link=topic=20641.msg237747#msg237747 date=1469135244] Thanks for the tip, I will check this tonight. (21-07-16, 11:35 PM)Bretty link Wrote: As above, new spark plugs and/or caps will likely sort that. Cylinders 3 & 4 are usually exposed to the elements if your bike spends anytime outside on the side stand. Spark plugs corrode, and a build up of dirt, water and corrosion around them doesn't help. The bike has been kept inside for the last year, the year before it was outside but on the centre stand and usually with a rain cover. But it probably had it's share of exposure to the elements since the #3 spark plug was stuck in the cylinder head. Several months of soaking it in WD40 and working it back and forth did the trick. When the carbs were put back in for the second time new plugs were fitted. I'm definitely going to check the caps and the leads! (22-07-16, 06:54 AM)darrsi link Wrote: Firstly you've not mentioned the air filter at all, when was it last changed and what type/brand do you have? I did check the air filter, it was a bit dirty, not too much though and I managed to shake and brush away most of the dirt out, I put it back in because I didn't have a new one at the time. The box is clean but the small breather filter had some gunk in it which I cleaned out. Rubber inlets are intact. I'm gonna get a new air filter just in case, should I get the OEM one like the one I have or should I go the K&N route? Or is the high flow of the K&N going to screw everything up more? Thanks so much for the link to the plug caps, they are at a great price! I did notice though that they don't have the 45 degree (more or less) elbow but I guess you didn't have issues with that since it has been done many times. I checked the position of the TPS with the speedometer, it showed a tad over 5000 RPM so I twisted it back on forth and made it land on 5000 but theres a lot of leeway on both sides before the RPM needle drops up or down. How can you tell if the sensor is failing? You mentioned that you're on the 4th now, did you measure the resistance in the faulty one when replacing it with a new one? Last but maybe fundamentally not least, the last fuel level measurement showed that carb #3 & #4 have about 1mm higher fuel level, could this tiny difference cause all this uneven running? Like I mentioned initially, cylinder #3 & #4 are running cooler that the rest, what's the logic here, is it because they don't get enough fuel or is it because they are getting too much fuel? Gonna check the spark plugs for colour later to get some indication. Thanks for all the replies! [/quote] I'm a big fan of the K&N air filter, it makes the throttle feel much more responsive in my opinion, and the bike generally feels like it can breathe properly. They do need cleaning more than it says on the box though, but I learned after a bit of research that washing powder has similar ingredients of the K&N own brand stuff and I've tried it and it works fine, but I still use the K&N oil to spray on once it's dry. The straight NGK caps have no issues at all, just a matter of preference I s'pose. Around the 5000rpm mark on the speedo is fine for the TPS. Just from experience I now even know when the TPS is not set in the right position, the bike does what I can only describe as a shivering effect, it's mild but when you know your own bike it's noticeable. It will tend to keep going out of position over time when it is failing, then with mine they eventually wouldn't land on the 5000rpm mark, the last one was stuck on 10,000rpm. Plus the bike by now will generally run rough at lower revs, normally anywhere up to 3000rpm, nothing major but again just not right. It feels like it's okay above that but it isn't really, it's just the bike noise and speed covering it up I reckon. As for different fuel levels in the carbs, is that not all part of balancing them out so they get equal fuel? Like I said earlier if other things aren't behaving or correct then balancing the carbs will give a false reading making the carbs unbalanced. I did it myself with a stuffed up air filter and the bike ran like crap. Cleaned the air filter and balanced them again a week later and the CarbTune was well out, but once levelled again it all worked lovely. Re: CARBURETTOR Problems In Low RPMs - YamFazFan - 22-07-16 (21-07-16, 09:59 PM)7uckyDog link Wrote: It sounds like it doesn't run on all 4 when idling and in low RPMs, but mid range and top is great. It passed MOT today and since I was at the shop they checked the temperature on each cylinder, 3 & 4 are running much cooler than the rest. That's just how mine was running up until a few weeks ago (except it was only cooler on down-pipe number 3). The workshop did an ultrasonic clean of the carbs and also fitted a new set of spark plugs. Apparently the main culprit was a blocked primary jet in number 3 carb. Re: CARBURETTOR Problems In Low RPMs - 7uckyDog - 28-07-16 (22-07-16, 08:10 PM)YamFazFan link Wrote: [quote author=7uckyDog link=topic=20641.msg237746#msg237746 date=1469134779] That's just how mine was running up until a few weeks ago (except it was only cooler on down-pipe number 3). The workshop did an ultrasonic clean of the carbs and also fitted a new set of spark plugs. Apparently the main culprit was a blocked primary jet in number 3 carb. [/quote] I have changed the plug caps which didn't make a difference but at least now I'll know I won't get a misfire from there. While I was at it I took the plugs out and #4 was a tiny bit whiter than the rest. If I recall correctly then that's a sign of a lean mixture. I think I will finally find some time tomorrow to rip the carbs off once again and inspect those jets. They have been cleaned with a carb cleaner twice already and air did flow through them and the channels in the carbs. So could there be an accumulation of dirt that formed some kind of a lime scale that could make those narrow channels even smaller to a point of being too narrow and the only way to clean them out would be by ultrasonic? Was it the cleaning of the jets or the cleaning of the carbs that solved the problem? Re: CARBURETTOR Problems In Low RPMs - His Dudeness - 28-07-16 I didn't read all the thread so this might have been suggested already but you said the initial problem was a rusty tank? Did you treat the rust in the tank? Or did you solve why it was going rusty in the first place? Was there water getting into it? You might have more water in there or more rust has got through clogging up the pilot jets. I think there's a filter in the tank too did you clean that? And did you replace the inline filter? If you've had rust problems in the past I'd be leaning towards a fuel supply issue than a spark issue Re: CARBURETTOR Problems In Low RPMs - 7uckyDog - 28-07-16 (28-07-16, 12:03 PM)His Dudeness link Wrote: I didn't read all the thread so this might have been suggested already but you said the initial problem was a rusty tank? Did you treat the rust in the tank? Or did you solve why it was going rusty in the first place? Was there water getting into it? You might have more water in there or more rust has got through clogging up the pilot jets. I think there's a filter in the tank too did you clean that? And did you replace the inline filter? If you've had rust problems in the past I'd be leaning towards a fuel supply issue than a spark issue Yes the rust was treated and a new inline fuel filter fitted, the fuel looks very clean so far. There's a filter in the tank, where the hell is that? This is definitely a fuel problem and I'm leaning towards the pilot jets as it's only in the lowest of RPMs. Has anyone had to replace them? Re: CARBURETTOR Problems In Low RPMs - His Dudeness - 28-07-16 There's one on the fuel tap in the tank. Come to think of it I had a mate who bought a bike with a rusty tank and he treated the tank with a sealer. It was running fine off a fuel bottle but it wouldn't idle when the tank was hooked up. Maybe he sealed up the filter when he was sealing the tank Re: CARBURETTOR Problems In Low RPMs - darrsi - 28-07-16 (28-07-16, 12:33 PM)His Dudeness link Wrote: There's one on the fuel tap in the tank. Come to think of it I had a mate who bought a bike with a rusty tank and he treated the tank with a sealer. It was running fine off a fuel bottle but it wouldn't idle when the tank was hooked up. Maybe he sealed up the filter when he was sealing the tank Just looking on the AJ Sutton site, I'm presuming you can't buy that filter as it's not listed as a separate item, just joined to the tap assembly? https://www.yamahamotorcyclespares.co.uk/genuineparts/9654/27/yamaha%20fzs600%20fazer/fuel%20tank?uID=0 Re: CARBURETTOR Problems In Low RPMs - His Dudeness - 28-07-16 You can pop them out and clean them. It's just an o ring holding them in. If you googled fuel tap filter you might find one. It might not be your problem, I think you'll have to check the pilot jets again but it's another thing to rule out Re: CARBURETTOR Problems In Low RPMs - YamFazFan - 28-07-16 [/quote] So could there be an accumulation of dirt that formed some kind of a lime scale that could make those narrow channels even smaller to a point of being too narrow and the only way to clean them out would be by ultrasonic? Was it the cleaning of the jets or the cleaning of the carbs that solved the problem? [/quote] The poor running issue with my bike was caused by degraded and/or evaporated petrol which had left deposits in the carbs. The workshop said that the main cause was the blocked pilot jet in number 3, but a general accumulation of muck was also contributing to it. The ultrasonic cleaning sorted it all out. It was a consequence of not riding/refuelling often enough. I also seem to remember reading somewhere that if you always store your bike on the side-stand for long periods it's more likely that this issue will occur in carbs 3&4. Re: CARBURETTOR Problems In Low RPMs - 7uckyDog - 29-07-16 So I managed to spend some time on the carbs today, too much for my liking as I'm going nuts over this. None of the jets looked blocked but I sprayed everything with carb cleaner, let it soak for a bit and then blew through all the passages I could find. This didn't change a thing, the engine idles like a sick dog. Could the passage for the pilot jet be clogged, what's the best way to clean it? Since the carb cleaner didn't work is the ultrasonic the only way? Where can I get ultrasonic cleaning, do most work shops provide this service? Doesn't the whole carb need to be submerged in order to ultrasonically clean the passages? Re: CARBURETTOR Problems In Low RPMs - darrsi - 29-07-16 How much does utrasonic cleaning cost? With the pain you're going through i'd be inclined to consider either handing it over to a pro with the bike and let them sort it, or even buying a used set of carbs. I know that's not ideal, especially if you prefer to do stuff yourself and don't want to be beaten by it, but i'm personally too impatient and would want it sorted asap. I dunno where you are but i've always given my bike to these lot when i've had carb/running troubles, not cheap but they certainly get the job done properly while you wait. http://pdq1.com/services/ http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xfzs+600+carbs.TRS0&_nkw=fzs+600+carbs&_sacat=0 Re: CARBURETTOR Problems In Low RPMs - 7uckyDog - 29-07-16 (29-07-16, 07:19 AM)darrsi link Wrote: How much does utrasonic cleaning cost? Yeah I like to do stuff myself since I can do a good job but I haven't done many carbs. I understand how they work but I prefer much more electronic injection as it's more reliable and you can do a custom mapping instead of painful jetting. I'm rarely beaten by mechanical things but last month I gave up on this and took the bike to a shop for carb balancing as I thought that might be a solution but the bike came out worse and was drowning in fuel, you could just smell it. I wasn't very happy and obviously took it back but now it's just back to how it was, waste of money that was. Used set of carbs is something I have thought about already but they all look so filthy on eBay so it would be just another cleaning job and probably a risk of getting a carb that is in a worse state than mine. I have almost totally lost my patience on this so I called PDQ (thanks for the suggestion) and they are booked until the third week of September! I had a long chat with one of their guys though and he confirmed my suspicion about the passage that lies beneath the pilot jet. He didn't recommend ultrasonic cleaning though, old school elbow grease is much better he said. He recommended getting a nylon wire or something small into the passage, give it a scrub with carb cleaner and blow it out. Hopefully that is going to save my mentality! Re: CARBURETTOR Problems In Low RPMs - YamFazFan - 29-07-16 (29-07-16, 07:19 AM)darrsi link Wrote: How much does utrasonic cleaning cost? To have mine cleaned and four new spark plugs supplied and fitted it came to a total of £187:58 Feels like a new bike now. http://www.cambridgemotorcycles.co.uk/ Re: CARBURETTOR Problems In Low RPMs - darrsi - 29-07-16 (29-07-16, 02:02 PM)7uckyDog link Wrote: [quote author=darrsi link=topic=20641.msg238226#msg238226 date=1469773147] Yeah I like to do stuff myself since I can do a good job but I haven't done many carbs. I understand how they work but I prefer much more electronic injection as it's more reliable and you can do a custom mapping instead of painful jetting. I'm rarely beaten by mechanical things but last month I gave up on this and took the bike to a shop for carb balancing as I thought that might be a solution but the bike came out worse and was drowning in fuel, you could just smell it. I wasn't very happy and obviously took it back but now it's just back to how it was, waste of money that was. Used set of carbs is something I have thought about already but they all look so filthy on eBay so it would be just another cleaning job and probably a risk of getting a carb that is in a worse state than mine. I have almost totally lost my patience on this so I called PDQ (thanks for the suggestion) and they are booked until the third week of September! I had a long chat with one of their guys though and he confirmed my suspicion about the passage that lies beneath the pilot jet. He didn't recommend ultrasonic cleaning though, old school elbow grease is much better he said. He recommended getting a nylon wire or something small into the passage, give it a scrub with carb cleaner and blow it out. Hopefully that is going to save my mentality! [/quote] Yeah i forgot to mention PDQ are very human over the phone as well as in the workshop, they actually do give a shit about bike problems and will point you in the right direction. Gotta remember the age of these bikes so unless you buy new then all carbs are gonna look grubby, it's what's going on inside that counts though. For the record, a new set of carbs is £611, but you do get a free delivery :lol |
