Pitted Pots - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Pitted Pots (/showthread.php?tid=76131) |
Pitted Pots - celticdog - 13-07-16 Having a bit of a mare with the blue spots (well one of them) at the moment. I know it hurts but it looks like i'm going to have to spend some money :'( Has anyone bought new pistons and seals lately, are the fleabay ones any good? There's a fair variety of prices out there. Re: Pitted Pots - yemisiblake - 13-07-16 What's the problem? Sent from my SM-G900F using Tapatalk Re: Pitted Pots - His Dudeness - 13-07-16 They look alright to me. Are they moving alright? I doubt the corroded bit would ever touch the seals so you should be alright. If you want to replace them go for Yamaha ones! Re: Pitted Pots - Dave48 - 14-07-16 Have used Powerhouse Automotive (Chesterfield) for all things braking for last few years. They have a good reputation & are a whole bundle of £ cheaper than Yamaha OEM. Also unlike some pattern components eg seals, their products fit properly. For non-mechanical owners they offer a caliper rebuild service. No I am not sponsored to say this but praise where praise is due.... Re: Pitted Pots - celticdog - 14-07-16 The pots have been sticking on one side for a while now, with one pot almost failing to move. Unfortunately I've got the dreaded low speed grabbing. Visually there appears to be no run-out on the discs, so I'm going to explore everything else. The Powerhouse stuff looks good, I think give the pots a good clean and fit new seals to see if it makes a difference. Funny thing, the wheel was reasonably free to rotate when off the ground, but was binding and hard to turn when I tried to rotate backwards. It took me a good bit of pumping to get all the pots out into the middle position as in the pic. Re: Pitted Pots - darrsi - 14-07-16 (14-07-16, 11:17 AM)celticdog link Wrote: The pots have been sticking on one side for a while now, with one pot almost failing to move. Unfortunately I've got the dreaded low speed grabbing. Visually there appears to be no run-out on the discs, so I'm going to explore everything else. The Powerhouse stuff looks good, I think give the pots a good clean and fit new seals to see if it makes a difference. Funny thing, the wheel was reasonably free to rotate when off the ground, but was binding and hard to turn when I tried to rotate backwards. Could that not have been caused by you putting the pads back in on different sides? May just need bedding in again. Re: Pitted Pots - Freck - 14-07-16 That file stuck in the middle isn't going to help things. :pokefun Re: Pitted Pots - dangerousdave - 14-07-16 These look perfectly fine to me, I'd just clean them up with some very fine sandpaper! I did have a front brake grabbing problem which was rectified by copper greasing the lever pivot bolt. |
