Clock transfer - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Clock transfer (/showthread.php?tid=76116) |
Clock transfer - sinto607276 - 11-07-16 I want to change my 1998 clocks to 2003 set, got all the wiring looms etc but the white connectors are different under the tank, now scratching my head as I thought it was a straight swap but needs a wee bit more thinking, so have any of you guys done this and can give me some ideas? Cheers. Re: Clock transfer - joebloggs - 11-07-16 Find the pin out diagram for both models and see if the wiring is compatible. You could temporarily connect them with scotch blocks before cutting any wires. Re: Clock transfer - sinto607276 - 17-07-16 (11-07-16, 11:54 PM)joebloggs link Wrote: Find the pin out diagram for both models and see if the wiring is compatible.Looked at those diagrams :eek But it now looks like I've got a set of clocks that won't fit ![]() on the hunt now for upto a 2002 set as these apparently fit (the ones with the clock added to the speedo and not the rev counter) although I still need the wiring loom as well as its got a couple of extra wires for the clock but it's just plug and play (here's foccin hoping anyhow) :lol |
