Back steer light is not working - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Back steer light is not working (/showthread.php?tid=76027) |
Back steer light is not working - krystof.ka - 04-07-16 Hello, my back left steering light stopped working and the front one on the same side is flickering really fast. Could I please ask you for an advice what to do? Kind regards Krystof Re: Back steer light is not working - His Dudeness - 04-07-16 The bulb has probably come loose or blown. Take the cover off the one that's not working and have a look at the bulb. Check for corrosion in the bulb holder. A spray of wd 40 and a wiggle of the bulb should fix it if it's not blown Re: Back steer light is not working - krystof.ka - 04-07-16 (04-07-16, 05:46 AM)His Dudeness link Wrote: The bulb has probably come loose or blown. Take the cover off the one that's not working and have a look at the bulb. Check for corrosion in the bulb holder. A spray of wd 40 and a wiggle of the bulb should fix it if it's not blown Unfortunately, this didnt help. Thank you. K Re: Back steer light is not working - Fazerider - 04-07-16 If the bulb and socket are OK, check the connections to the socket and the flying leads at the frame end of the indicator stalk. Re: Back steer light is not working - Jules-C - 04-07-16 Most likely is the bulb is blown. Swap it with one from the other side and see if the problem moves to the other side as well |
